Free particle: expectation of x for all time with Ehrensfest
In summary, the free particle in one dimension is described by:-H = \frac{p^2}{2m} = \frac{\hbar}{2m}\frac{\partial^2}{\partial x^2}-at t = 0, the wavefunction is described by:-\Psi(x,0) = N(a^2-x^2) e^{i k x} for |x| \leq a-outside a, \Psi = 0.
renec112
35
Hello physics forums. I'm trying to solve an old exam question. Would love your help.
A free particle in one dimension is described by:
## H = \frac{p^2}{2m} = \frac{\hbar}{2m}\frac{\partial^2}{\partial x^2}##
at ##t = 0##
The wavefunction is described by:
## \Psi(x,0) = N(a^2-x^2) e^{i k x}## for ##|x| \leq a##
outside ##a##, ## \Psi = 0##. Use Ehrenfest to find the expectation value for all later times ##<x(t))>## of the particles position for all time ## t \geq 0 ##.
Ehrensfest:
\frac{d<Q>}{dt} = \frac{i}{\hbar}<[H,Q]> + <\frac{\partial Q}{\partial t}>
Where ##Q## is an operator.
We need to find it for all later times, Ehrensfest will show how an operator evolves in time. So set ##Q = x## and use Ehrenfest. Then we know the poisiton for all later time.
\frac{d<x>}{dt} = \frac{i}{\hbar}<[H,x]> + <\frac{\partial x}{\partial t}>
Since the operator does not change in time we have:
Here is where i am stuck. I am trying to do the commutator:
\frac{d<x>}{dt} = \frac{i}{\hbar}<(Hx -xH>
However, these do commute and hence everything should be zero.
What do you think?
renec112 said:
However, these do commute ...
Can you show that this is true?
Likes renec112
Actually when you say it like that..
I guess i thought in
the ##p## is just a constant but off course it's an operator:
##p = i \hbar \frac{\partial}{\partial x}##
I guess the only thing to do is to differentiate a couple of times and then take the inner product :D
\frac{d<x>}{dt} = \frac{i}{\hbar}<Hx -xH>
= \frac{i}{\hbar}<\frac{\hbar}{2m}\frac{\partial^2}{\partial x^2} x -x\frac{\hbar}{2m}\frac{\partial^2}{\partial x^2}>
= < \Psi | \frac{i}{\hbar}<\frac{\hbar}{2m}\frac{\partial^2}{\partial x^2} x -x\frac{\hbar}{2m}\frac{\partial^2}{\partial x^2} | \Psi>
Seems legit?
Thank you for helping me.
It's legit, but you need to advance it further. Remember that ##[x,p_x] = i \hbar##. There is also a useful identity about commuting operators, that says$$[AB,C]=A[B,C]+[A,C]B.$$ Prove it then use it. What do you think ##A##, ##B## and ##C## should be identified as?
Likes renec112
Oh I see. That's very smart.
This is what i did:
##\frac{d<x>}{dt} = \frac{i}{\hbar} <[H,x]>##
insert hamilton
##= \frac{i}{\hbar} <[P^2/2m,x]>##
##= \frac{i}{2 m \hbar } <[PP,x]>##
##= \frac{i}{2 m \hbar } <P[P,x]+[P,x]P>##
##= \frac{i}{2 m \hbar } <-P[x,P]-[x,P]P>##
##= \frac{i}{2 m \hbar } <-P i \hbar-P i \hbar>##
##= \frac{1}{m} <P>##
And i already calculated ##<P>## from another task.
Not sure if it's correct, but it feels like it. Thank you very much for helping me out :) !
Classically, what is v in terms of p?
Likes renec112
## v = \frac{1}{2} m v^2##
## = \frac{m^2v^2}{2m}##
## = \frac{p^2}{2m}##
## \Rightarrow p = \sqrt{2 v m}##
Like this?
Like this?
Nope. To begin with, ##\frac{1}{2}mv^2## is kinetic energy ##K##, not speed. What is the classical definition of momentum? Look it up if you forgot.
Likes renec112
Thanks for helping me :)
Its ##p = mv## off course.
Oh i so the m' cancels and i am left with only ##<x>##... Nice trick ! Thank you :)
Not so fast. So far, you have established that ##\frac{d<x>}{dt}=<v>=\frac{1}{m}<p>##. You have not found ##<x>##.
Likes renec112
Oh right.. I think i misunderstood the question then.
I need to find ##< x(t)> ## for all later times.
But i can't see, how i can find that.. You are saying ##\frac{d<x>}{dt} \neq < x(t)> ##
I am not sure why i should fine ##< x >## I can see it's a part of the equation, but why does it give me ##<x(t)>## for all later times?
I only know how to find ##<x>## when ##t = 0##. Then it's just: ##< \Psi(x,0) | x | \Psi(x,0)>##
Thank you for the comment! appreciate it :)
Related to Free particle: expectation of x for all time with Ehrensfest
1. What is a free particle?
A free particle is a concept in physics that refers to a particle that is not under the influence of any external forces. It is not bound to any potential and therefore has a constant energy.
2. What is the expectation of x for all time for a free particle?
The expectation of x for all time for a free particle can be calculated using the Ehrenfest theorem, which states that the expectation value of position for a free particle is equal to its initial position multiplied by the time elapsed.
3. How is the Ehrenfest theorem applied to calculate the expectation value of x for a free particle?
The Ehrenfest theorem states that the expectation value of position for a free particle is given by x(t) = x0 + vt, where x0 is the initial position and v is the velocity of the particle. Thus, the expectation of x for all time can be calculated by simply multiplying the initial position by the time elapsed.
4. Is the expectation of x for all time the same as the classical trajectory of a free particle?
Yes, the expectation of x for all time for a free particle is equivalent to its classical trajectory. This is because, in the absence of external forces, a free particle will continue to move with a constant velocity, resulting in a linear position-time graph.
5. Does the expectation value of x for a free particle change over time?
No, the expectation value of x for a free particle remains constant over time since the particle is not under the influence of any external forces. This means that the particle's position will not change unless acted upon by an external force.
