Free vibration of 100 DOF spring
In summary: The energy is spreading to the neighboring springs and masses, and as a result, the response decays rapidly.
kajalschopra
40
Hi,
I have just started reading of "finite element model updating" which is a statistical means of updating the finite element model when there is source of uncertainty in the modelling parameters, modelling error, etc.
My question below is NOT related to finite element model updating but to a free vibration problem of linear spring with 100 degrees of freedom. I came across this problem whilst reading a textbook on the subject of "Finite element model updating"
Let us consider a 100 degree of freedom system linear spring as shown in the figure below;
The figure below shows the free vibration of a mass M50 located in the middle.
Note: Initial conditions - zero initial conditions except that the mass at the right end has an initial displacement of 0.01 m.
The figures below zoom into the first and last 5 seconds of the response.
First 5 seconds
Last 5 seconds
Following points may be observed from the above figures (as stated in the text I am reading)
1) Response of first 0.6 seconds was almost 0 since the wave has not yet arrived
My question: What is the wave that the author talks about here?2) After the first wave arrived, the respond reached maximum and decayed rapidly
My question: Again what is this first wave? It is a free vibration problem. There is no damping in the model. Why does the response decay?
3) If the response of the last 5 seconds is taken, you get random response.
What is the reason of behaviour 1,2 and 3 ?
IS it a redundant problem with insufficient information?
Is it an incorrectly formulated problem?
Please can anyone help?
The compression wave. Slightly displacing the last mass creates a sound wave that will then propagate in the system.
The decay is due to the fact that wave continues to travel along the springs. The energy is spreading to the neighboring springs and masses.
kajalschopra said:
3) If the response of the last 5 seconds is taken, you get random response.What is the reason of behaviour 1,2 and 3 ?
Because of the high number of degrees of freedom, after a while you get the masses moving about in a random fashion, similar to gas particles bouncing off each other.
The perturbation front . It could take a relatively long time for the disturbance caused by perturbing the RH outer mass to reach the number 50 mass .
On the first pass all springs and masses to the left of the perturbation front are undisturbed and have no motion . All those springs and masses to the right of the right of the perturbation front are disturbed and are in motion .
Do the sums for a system with a manageable number of springs and masses .
Slinky
Dear All,
Thank you very much for the answers. Can I say as below:
That means: The wave corresponds to the disturbance / perturbation . IT take about 0.6 seconds for the disturbance to travel from the outermost mass (100th mass) to reach the 50th mass. Had it been the first mass, it would have taken more than 0.6 seconds. Am I right?
The decay is due to the fact that the perturbation / disturbance has traveled from 50th mass to innermost masses. The disturbance has been distributed. Am I right?
3)
Distribution of the disturbance means reaching a steady state which is (in this case) a random vibration. Am I right?
Thanks again
Kajal
Can anyone please confirm that the above (what I stated) are correct?
With affection,
Kajal
Correct. You can use the observation to figure out the speed of sound in the system.
Initially, it is not yet distributed, but mostly just passes along to the innermost masses. This is why it looks exactly like a damped oscillation. Note that the amplitude of the oscillation goes back up as the wave bounces back from the wall. In time, the perturbation gets distributed over all masses.
I would say that the system reaches an internal equilibrium.
I've watched this happen in a vibration lab . Just a small number of springs and masses connected in series . Odd thing though is that the motion did not always transition slowly from systematic to chaotic . In some experiments the motion flipped from systematic to chaotic almost instantly .
Really though using a simple axial force/displacement model for systems where there are more than a few springs and masses is not very realistic . There are other things going on which could modify the motion considerably
Could it be when the springs can longer be considered linear?
The large motion disturbance wave moves along the system at a rate determined by the dynamic characteristics of the springs and masses .
The speed of sound in the metal of the springs determines the maximum speed at which the associated stress wave can propagate .
Almost certainly due to effects of imperfections in the springs causing non linearity and off axis secondary motions . There is always going to be some damping as well but effect of that is difficult to estimate .
Dear All,
Thank you for the reply.
1) Do you think that this problem is unrealistic? That is, not a 'practical problem'?
Do you think the problem is not completely defined? That is, for it to be completely defined, initial states of more degrees of freedom should have been provided than just the outermost degree of freedom?
2)
I've heard this before, that is, using the observation to figure out the speed of sound in the system. I do not physically understand that how is this related to 'speed of sound'With regards and affection,
kajal
To the contrary, I think this is a very interesting problem. It allows to understand some fundamental things about wave propagation. And the system is completely defined, since all springs are at their equilibrium position, except one.
The speed of sound is the same as the speed of propagation of the perturbation. Sound is simply a propagating compression wave.
Your system with a large number of springs and lumped masses is not very realistic in terms of being a practical piece of hardware but the general principles of setting up models this way and the solution methods have many applications .
Lumped mass plus springs approximations are used extensively in computer modelling of many types of structure . The most common applications are in determining the static and dynamic response characteristics of beams and shafts .
Any real structural system can in principle be analysed using purely analytic methods but obtaining actual solutions is sometimes very difficult . Modelling the system using a lumped mass plus springs approximation usually means that numerical solutions can be obtained relatively easily .
Related to Free vibration of 100 DOF spring
1. What is meant by "free vibration" in the context of a 100 DOF spring system?
In the context of a 100 DOF (degrees of freedom) spring system, "free vibration" refers to the natural oscillations of the system without any external forces or disturbances. This means that the springs and masses in the system will vibrate back and forth in a repetitive pattern at their natural frequencies.
2. How is the natural frequency of a 100 DOF spring system determined?
The natural frequency of a 100 DOF spring system is determined by the stiffness of the springs and the mass of the individual masses attached to the springs. The higher the stiffness and lower the mass, the higher the natural frequency will be. It can be calculated using the equation f = 1/2π√(k/m), where f is the natural frequency, k is the spring stiffness, and m is the mass.
3. What factors can affect the free vibration of a 100 DOF spring system?
The free vibration of a 100 DOF spring system can be affected by various factors such as the stiffness and mass of the individual springs and masses, damping in the system, and any external forces or disturbances. Changes in these factors can alter the natural frequencies and patterns of vibration in the system.
4. How can the free vibration of a 100 DOF spring system be analyzed?
The free vibration of a 100 DOF spring system can be analyzed using mathematical modeling and simulation techniques. This involves creating a mathematical representation of the system and solving equations of motion to determine the natural frequencies and mode shapes of vibration. Computer software can also be used to simulate and visualize the behavior of the system.
5. What are some practical applications of understanding the free vibration of a 100 DOF spring system?
Understanding the free vibration of a 100 DOF spring system is important in various engineering and scientific fields. It can be used to design and optimize structures and machines that involve springs and masses, such as buildings, bridges, and vehicles. It can also be applied in fields such as acoustics, seismology, and aerospace engineering to study the vibrations of structures and systems in real-world scenarios.
  • Mechanical Engineering
  • Beyond the Standard Models
