- #36
- 22,210
- 13,785
eltodesukane said:Would an accelerometer measures a non-zero acceleration aboard the ISS?
No.
A.T. said:Similar issues discussed here:
https://www.physicsforums.com/threads/einstein-says-objects-do-not-fall-to-the-earth.781200/
Orodruin said:No, this is the wrong interpretation. You are not accelerating in free fall. (We are here talking about what is called proper acceleration, which is what an accelerometer measures.) Movement is relative.
You need to differentiate between coordinate acceleration and proper acceleration. It was clearly stated in my post that I was talking about proper acceleration (which is the frame independent quantity). Regardless of the observer, a free falling object has zero proper acceleration.victorneto said:Imagine the free fall of a body toward the earth, like falling off a ladder, or an astronaut in a spaceship orbiting the Earth. Both are in free fall situation. A fixed observer on the Earth's surface, notice the astronaut or body in free fall with an acceleration g. Already for a comoving observer, or on the falling bodies, there is no acceleration. "They do not feel their own weight."
Yes, that's also what any accelerometer will tell you. You probably have one in your phone. The surface has a proper acceleration upwards, just like the green apple still hanging on the tree (in Einsteins model):inertiaforce said:Yes there are two more videos in that similar thread where both Brian Greene and Brian Cox are saying the same thing, that the Earth is apparently accelerating upward.
write4u said:Just for clarity. Is a photon in a constant state of acceleration? Is anything that ceases to increase in speed still in a state of acceleration?
stevendaryl said:No, a photon isn't accelerating. However, it's kind of interesting to relate it to accelerated motion.
If you have a rocket that is undergoing constant proper acceleration in a straight line of magnitude [itex]g[/itex] (that's the acceleration that would be "felt" by people on board the rocket), then its position as a function of time (as measured in an inertial frame) is given by:
[itex]x = \sqrt{c^2 t^2 + \frac{c^4}{g^2}}[/itex]
(if you choose the origin for [itex]x[/itex] appropriately--that's my third parenthetical remark in a single sentence; is that some kind of record?)
Anyway, the path of a photon is [itex]x=ct[/itex], which is the limit as [itex]g \rightarrow \infty[/itex]. So it's not accelerating, but its motion is sort of the limit of infinite acceleration.
write4u said:IMO, a massive object in free-fall does accelerate until terminal speed is achieved.
In relativity it is axiomatic that photons cannot accelerate in the classical sense, 'c' is a constant for all photons.write4u said:Thus the question if a photon is also constantly accelerating but unable to break (c).
PeterDonis said:Accelerate (in the sense of coordinate acceleration--an object in free fall has zero proper acceleration) relative to what? "Terminal speed" relative to what? Since we're talking about objects in a vacuum, what does "terminal speed" mean?
https://en.wikipedia.org/wiki/Terminal_velocity
write4u said:https://en.wikipedia.org/wiki/Terminal_velocity
I read that to mean that at "terminal velocity" acceleration becomes zero. But what happens in between stationary and terminal speed, is the object accelerating until it reaches terminal speed?
write4u said:I read that to mean that at "terminal velocity" acceleration becomes zero.
write4u said:is "c" not a terminal speed, even in a vauum?
inertialforce,inertiaforce said:Yes there are two more videos in that similar thread where both Brian Greene and Brian Cox are saying the same thing, that the Earth is apparently accelerating upward. I will link the videos here for reference:
This video from 9:30 onward (Brian Greene): youtube, HneFM-BvZj4
This video, where Brian Cox says that a ball and a feather aren't falling to the earth: youtube, E43-CfukEgs
So that's a total of 3 videos including the one in the original post.
So what the hell is going on here lol?
write4u,write4u said:Just for clarity. Is a photon in a constant state of acceleration? Is anything that ceases to increase in speed still in a state of acceleration?
The movement of a piece of surface is frame dependent, but the surface definitely doesn't move outward as a whole because the radius is constant. The frame invariant proper acceleration of the surface doesn't imply movement.Wes Tausend said:In a nutshell, Equivalence principle. The earth, consisting of matter as cause, acts just as though it's surface is moving upward, or at least outward in an accelerated manner. The floor rises to meet "falling" objects.
Proper acceleration and movement are different things. The surface pieces on opposite sides have opposite proper acceleration, but in curved space-time that doesn't imply moving apart.A1337STI said:on opposite sides of the Earth drop an apple. the planet can't move in both directions at once,
A1337STI said:I need to find some "curved spaced time" reading for dummies.. i feel like my understanding of how things work is severely lacking. :(
A.T.,A.T. said:The movement of a piece of surface is frame dependent, but the surface definitely doesn't move outward as a whole because the radius is constant. The frame invariant proper acceleration of the surface doesn't imply movement.Wes Tausend said:In a nutshell, Equivalence principle. The earth, consisting of matter as cause, acts just as though it's surface is moving upward, or at least outward in an accelerated manner. The floor rises to meet "falling" objects.
The proper physical radius doesn't change according to GR, which we should stick to in this forum.Wes Tausend said:"...The radius is constant"...
I find I must conveniently accept this convention too
No, it's space-time curvature that allows proper acceleration in opposite directions, without changing the proper distance. The speed limit c is irrelevant here, because the opposite surface pieces don't move at all relative to each other.Wes Tausend said:SR may our only salvation needed, or even available, to logically assert, "The frame invariant proper acceleration of the surface doesn't imply movement."
I agree. I am merely pointing out the extent of Equivalence by simple observation. Equivalence, along with SR are definitely always part of GR. My references to acceleration and motion are Einstein's thought experiment (see post #33) which resulted in Equivalence and therefore GR. Do you have an equally good reference why we cannot refer to such equivalent motion in GR?A.T. said:The proper physical radius doesn't change according to GR, which we should stick to in this forum.
I disagree. I see the curvature as the direct result of the bending of light, therefore incorporating SR, also discussed in post #33.A.T. said:No, it's space-time curvature that allows proper acceleration in opposite directions, without changing the proper distance. The speed limit c is irrelevant here, because the opposite surface pieces don't move at all relative to each other.
Wes Tausend said:...
The equivalence principle applies only locally, and cannot be used to deduce that the radius of the Earth changes, because space time curvature is not negligible over this large area.Wes Tausend said:I agree. I am merely pointing out the extent of Equivalence by simple observation.
See the interior Schwarzschild solution, where the proper radius doesn't change over time.Wes Tausend said:Do you have an equally good reference why we cannot refer to such equivalent motion in GR?
This is backwards, vague and doesn't disprove what I said:Wes Tausend said:II disagree. I see the curvature as the direct result of the bending of light, therefore incorporating SR, ...
Wes Tausend said:We are discussing something controversial.
