Freewheeling bicycle and friction
In summary, if the surface of the road is the same as the slope, the bicycle will travel for a total of 113 meters before coming to a complete stop.
Worthatry
Background question:
A bicycle and rider have a combined mass of 75 kg. They freewheel down a slope whose maximum height is 6 meters above sea level. The slope is 20 meters long. At the end of the slope, the bicycle and rider are traveling with a velocity of 10 m/s. Calculate the work done against friction whilst descending the slope.
Answer reached:
mass = 75 kg
max. height = 6 meters
slope = 20 meters
Vf = 10 m/s
PE at start = KE at end + work done to overcome friction.
mgh = 1/2mv2 + friction force x distance moved against friction.
= 75 x 9.81 x 6 = 1/2 x 75 x 102 + f x 20
= 4414.5 = 3750 + 20f
= 4414.5 - 3750 = 20f
= 664.5 = 20f
Force = 664.5/20
Force = 33.225N
Question needing assistance with:
Using the calculated values from the question above, calculate how far the bicycle will travel before coming to a stop if the surface of the road is the same as the slope. State why this distance would not be achieved in a real world experiment.
Forgot to show my attempt...
Force = change of momentum/time
33.23N = (75 x 10) - (75 x 0)/time
33.23N = 750/time
time = 750/33.23 = 22.6s
It will take 22.6s to come to a complete stop.
Find distance = S = 1/2 (v-u) x t
S = 1/2 6 x 22.6
S = 113 meters
It will take 113 meters to come to a complete stop.
This would never happen due to air resistance.
Hi Worthatry,
Welcome to Physics Forums.
The question sort of hints that the surface is involved in the friction (although you correctly point out later that air resistance would likely be a factor, too). For your distance calculation you've assumed that the friction force remains the same for both segments of the journey, on the slope and on the level. Would this be true? How does one normally compute the force due to friction when the surface is a slope? How about when it's level?
gneill said:
Hi Worthatry,
This should be a different problem than a sliding down a slope (which is kinetic friction with the road). The bicycle tire is always in static contact with the road and is rolling. From experience, air resistance is the major source of friction, for situations like this. Air resistance is proportional to v^2, so it is not a constant, like was assumed to solve the problem.
I agree that in reality this scenario would not be properly modeled by sliding friction. Unfortunately the problem leaves the nature of the frictional losses quite vague except for the brief mention of the road surface. The OP did well to mention air resistance, but should probably flesh out the implications to properly answer the question for full marks.
It might be interesting to consider how applying a constant force (or force averaged over distance) model for friction affects the calculation accuracyif we consider different types of friction sources.
Likes scottdave
Most of the work would be done against air resistance and rolling resistance (principally, flexing the tyre walls). The only work done against friction would be against axle friction.
Given that it would be rolling resistance and axle friction, might need to be careful here.
Yes, the rolling resistance will be greater when the normal force is more (i.e. on the flat), but how linear is it?
Axle friction probably is linear with the normal force from the road.
Edit: according to section 2.2.3 of http://publications.lib.chalmers.se/records/fulltext/200040/200040.pdf, rolling resistance is linear with normal load.
Hi guys.
Thank you for your input. I am trying to work through all your replies, and applies these into an answer; which I am having difficulity doing. The level of this question is aimed at A Level Physics (18 yo). I have not worked with Physics for over 10 years, so it all seems blurred into one.
Again, I appreciate your input and welcome any simplified suggestions on how to complete this question.
Related to Freewheeling bicycle and friction
1. What is a freewheeling bicycle?
A freewheeling bicycle is a type of bicycle that has a mechanism which allows the rider to pedal forward without moving the rear wheel. This means that the pedals can rotate freely without causing the wheel to turn, allowing the rider to coast or slow down without having to use the brakes.
2. How does friction affect a freewheeling bicycle?
Friction plays a crucial role in the functioning of a freewheeling bicycle. Without friction, the pedals would not be able to turn the rear wheel and propel the bicycle forward. However, too much friction can also make it difficult for the pedals to rotate, making it harder for the rider to pedal.
3. What factors can affect the amount of friction on a freewheeling bicycle?
The amount of friction on a freewheeling bicycle can be affected by several factors, such as the condition of the bike's chain and gears, the type of lubrication used, the weight of the rider, and the surface on which the bicycle is being ridden.
4. How can friction be reduced on a freewheeling bicycle?
To reduce friction on a freewheeling bicycle, it is important to keep the chain and gears clean and well-lubricated. Choosing the right type of lubricant and regularly cleaning and maintaining the bike can help reduce friction and make pedaling smoother and easier.
5. How does a freewheeling bicycle differ from a fixed gear bicycle?
A fixed gear bicycle does not have a freewheel mechanism, meaning that the pedals and rear wheel always move together. This means that the rider cannot coast on a fixed gear bicycle and must continually pedal to keep the bike moving. In contrast, a freewheeling bicycle allows the rider to coast and pedal at their own pace.
