Frequency magnetics converting to tesla?
In summary, the conversation discusses the attempt to find a relation between a frequency magnetic field and the amount of tesla needed to induce a coil. The goal is to create a device using electromagnetics to locate and desalinate saline groundwater. The process involves understanding eddy currents, analyzing fields, and detecting phase shifts in saline at a significant depth. The speaker is seeking help and clarifications on the necessary field strength and frequency shift for their project.
Erik88
Hello,
For the last 2 months I've been trying to find a relation between a frequency magnetic field and the amount of tesla a coil has to induce. When I found this forum and I thought if somebody can help me it would be you guys.
I'm a student at the TU in Delft the Netherlands and I'm trying to make a device using geophysics to find saline groundwater and then pump up the water and desaline it.
This device uses electro magnetics to induce eddy currents in the soil which a receiver coil then measures and gives certain data. This magnetic field is a field with a frequency of 150, 500, 1000 and 2500 Hz. The depth I want to reach is minimum of 60 meters (180 feet) and the least inductive ground that we can have has a conductivity of 1 mS. Now to design the coil that needs to take care of this magnetic field we need the amount of tesla we need to calculate the current that flows through the coil.
I would be so happy if somebody knows how to do this!
Thanks!
Erik
There is no relation between the frequency of the oscillation of the magnetic field and the magnetic field strength. A stronger magnetic field will just give a stronger signal, and require a higher voltage and larger currents to drive the coil.
I'm afraid that your question is not very well formulated, suggesting that your knowledge of electromagnetics is somewhat cursory. (Forgive me if I'm wrong here.) Unfortunately, success at your task is best guaranteed by a mastery of that field. Understanding eddy currents at a level sufficient to answer your question, and others that you will need to answer but perhaps have not yet thought of, involves Maxwell's equations and advanced mathematical functions. After you have analyzed fields and eddy currents, and have designed your apparatus, you still have the challenging practical problem of detecting the miniscule phase shift caused by eddy currents in saline at a significant depth. I encourage you to increase your E&M skills and/or partner with someone who has them.
Oke thanks!
I've had some courses on electromagnetics but they were somewhat simpler than this problem. But mfb, if I'm correct I just need to know what the minimum change in phase shift needs to be for the receiver coil so I know the minimum strength of the magnetic field at a certain depth and then calculate the corresponding amount of tesla needed?
I would not expect a field strength-dependent frequency shift. I think a stronger field just makes the detection easier/more precise.
Okay thanks! I think this makes my job already a lot easier!
Related to Frequency magnetics converting to tesla?
1. What is frequency magnetics?
Frequency magnetics refers to the study and manipulation of electromagnetic fields at different frequencies. This can include the production and control of magnetic fields, as well as the conversion of frequency to other units, such as tesla.
2. How is frequency related to tesla?
Frequency and tesla are two different units of measurement for electromagnetic fields. Frequency is a measure of the number of cycles per second of an electromagnetic wave, while tesla is a measure of the strength of a magnetic field. The two are related through the equation B = 2πfμ, where B is the strength of the magnetic field, f is the frequency, and μ is the permeability of the medium.
3. What is the significance of converting frequency to tesla?
Converting frequency to tesla allows us to better understand and manipulate electromagnetic fields. By converting frequency to tesla, we can measure the strength of a magnetic field, which is important in a variety of fields such as physics, engineering, and medicine.
4. How is frequency magnetics converting to tesla used in real-world applications?
Frequency magnetics converting to tesla is used in a wide range of real-world applications. For example, in medical imaging, magnetic resonance imaging (MRI) machines use frequency magnetics to convert radio frequency signals into tesla measurements, allowing for detailed images of the inside of the body. In engineering, frequency magnetics converting to tesla is used in the design and testing of electrical systems, such as power grids and electronic devices.
5. What are some challenges in frequency magnetics converting to tesla?
One of the main challenges in frequency magnetics converting to tesla is the accuracy and precision of the measurements. This requires precise equipment and careful calibration. Additionally, the conversion may be affected by external factors such as temperature and interference from other electromagnetic fields, which must be accounted for in order to obtain accurate results.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
