Frequency of Differently Coloured Light
In summary, when a torch emitting white light is covered with a red cellophane paper, the resulting light appears red because all other colors have been removed. This new beam of red light does not have a new frequency, but rather is a mixture of different frequencies that our eyes perceive as red. However, this perception of color is not a true representation of the actual frequencies present, as our eyes and visual cortex have limitations in accurately perceiving and processing colors. This is why optical instruments are necessary for spectroscopic experiments.
Michelleeeee
We know that light of a specific colour has a specific frequency. Suppose we have a torch emitting white light, and we place a, say, red cellophane paper, in front of it. Now we would have red light. So does this mean the new beam we get has a new frequency? How?
Science news on Phys.org
White light is not a single color. What you've done with the cellophane is remove all the other colors but red.
Likes Michelleeeee and Bystander
There is a common idea that for every color there is a frequency and for every frequency there is a color. That is only true for "spectral" colors - monochromatic light. https://en.wikipedia.org/wiki/Spectral_color
Most of the colors we encounter in everyday life are mixtures of a bunch of frequencies with different amplitudes at each frequency. To fully characterize such a "color", one would have need a graph of the distribution of amplitudes across the frequency range. Human color vision does not give us such a graph. At a simplified level, we have three types of light sensing bodies in the eye. So our eyes obtain, in effect, only three numbers which we use to characterize the complete frequency distribution. https://en.wikipedia.org/wiki/Trichromacy.
There is a lot of post-processing that goes on in the visual cortex to render the image that we end up perceiving. The relationship between the colors that hit our eyes and the colors that we think we see is more complex than is conveyed above. For instance, context matters. If it is sunset and the entire landscape is illuminated with reddish light, our visual cortex can compensate and still report (albeit with lowered efficiency) a brown fox hiding under a green bush.
Likes Michelleeeee
Do not be confused with what your eyes observe with what it actually is. Your eyes, and your optical system, see the color "white" when a bunch of different frequencies are mixed together. This is not what an optical instrument observe, because such an instrument can distinguish different frequencies that make up white light.
It is why we do not perform spectroscopic experiments using our eyes as the detector.
Zz.
Likes sophiecentaur and Michelleeeee
thanks a lot, everyone! :D
Related to Frequency of Differently Coloured Light
What is the relationship between frequency and color of light?
The frequency of light is directly related to its color. Higher frequency light appears bluer, while lower frequency light appears redder.
How is the frequency of light measured?
The frequency of light is typically measured in units of hertz (Hz), which is equivalent to cycles per second. In the electromagnetic spectrum, the frequency of light is measured in terahertz (THz) or petahertz (PHz).
What is the visible spectrum?
The visible spectrum is the range of frequencies of light that are visible to the human eye. This includes all the colors of the rainbow, from red to violet.
How does the frequency of light affect its energy?
The frequency of light is directly proportional to its energy. This means that higher frequency light has more energy than lower frequency light. This is why blue light, which has a higher frequency, is more energetic than red light.
Why do different colors of light have different frequencies?
Each color of light has a different frequency because it has a different wavelength. Wavelength and frequency are inversely related, so as the wavelength of light increases, its frequency decreases. This is why red light, which has a longer wavelength, has a lower frequency than blue light.
  • Optics
  • Optics
