B Frequency of EM Waves from Monitor for Black/White & Color Images
The discussion centers on the electromagnetic wave emissions from an older monitor model, specifically whether these emissions vary with the screen's color. It highlights that power consumption changes between black and white screens due to less pixel activity, but the frequency of emissions remains constant. Concerns about radiation from flat-screen monitors are deemed less significant compared to risks from other common activities, such as smoking or using mobile phones. The conversation also touches on electromagnetic hypersensitivity (EHS), noting that while symptoms are real, there is no scientific evidence linking them to electromagnetic fields below safety guidelines. Ultimately, the thread concludes that there is no established danger from modern monitors, aside from specific risks associated with older CRT technology.
EleSuki
TL;DR Summary
Are older monitors more likely to leak electromagnetic radiation? If so, I hypothesized that people with electromagnetic hypersensitivity might have symptoms caused by older monitors.
I am using an old monitor (MITSUBISHI RDT27IWLM). The power consumption changes when the screen is white or black, but does the frequency of the weak electromagnetic waves emitted from the monitor change? Or is the frequency the same, only the output is stronger/weaker?
A black or white screen does not have detailed information to display, so the spectrum is lower in RF radiation energy, and less pixel logic transitions results in less power consumption.
Worry about hypothetical radiation from a flat screen monitor, will injure you more than the weak RF emissions from your monitor.
Smoking, driving cars, using mobile phones, or using CRT screens that emit x-rays, are very much more dangerous, and will hide any effects from a flat screen.
Likes Bystander and sophiecentaur
EleSuki said:
TL;DR Summary: Are older monitors more likely to leak electromagnetic radiation? If so, I hypothesized that people with electromagnetic hypersensitivity might have symptoms caused by older monitors.
The reason for this is not particularly clear for an "old" monitor like yours. I googled the model but couldn't find the technology; it may be newer than you think, in terms of its system. I did find that the power supplied is 57W(?) which is very very low when you think that most of this will emerge as light, leaving very little to be 'radiated' as em/ radio frequency waves.
In truly old sets, the majority of the power is supplied to the backlight, behind the LDC picture elements and that is illuminated all the time. The lcd elements block. More modern sets use LEDs as backlighting for the LCDs and a brighter screen gives more power to those LEDs. So I wonder by just how much the power into your monitor changes; a lot or just a few percent?? Did you measure it? The rest of the circuitry (digital) consumes very little power.
If you want to talk about dangerous or harmless radiation from TV sets then the X Rays produced where high velocity electrons hit the front of the screen of a colour CRT are enough of a potential hazard that the glass front is made thick enough to absorb the majority. Also, the power of the magnetic fields which are used to deflect the electron beams is sufficient to cause interference at around 16kHz. But that's all ancient history.
The worst effect of watching TV monitors is the way the light can affect your diurnal rhythms. Modern laptops change the colour temperature of the display in later hours in an attempt to reduce the damage. Plus, as I tell my grandkids, watching too much TV gives you square eyeballs.
Likes Bystander
There is no such disease/disorder accepted by the mainstream medical community. While the symptoms are accepted as being real, there is little evidence linking them to electromagnetic radiation or fields.
Per ARPANSA (Australian Radiation Protection and Nuclear Safety Agency):
On the basis of current scientific information, there is no established evidence that EHS is caused by EMF at levels below exposure guidelines. ARPANSA acknowledges that the health symptoms experienced by the affected individuals are real and can be a disabling problem, and advise those affected to seek medical advice from a qualified medical specialist.
As the posts above say, there is no known danger from computer monitors or TV's except in the specific case of x-rays produced by CRT's, which are absorbed by the glass before they can get out and harm anyone.
Since this discussion is based on the premise of a medical condition existing that isn't known to actually exist I am locking this thread.
Likes Bystander and berkeman
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
