Frequency of Modulated Signal: Carrier vs Message
In summary, the message signal added sidebands to the carrier frequency. This allows the message to be distinguished from the carrier and the sidebands are what carry the message information.
Ocata
198
If a carrier signal is 1000 Hz, and my message signal has a bandwidth of 100 Hz.
Is there any change in frequency of the modulated signal? Why is it said that the message signal is now operating between 1000hz +/- 100Hz? I thought the original message signal frequency remains unchanged when superimposed on the carrier signal. Does the carrier signal portion of the A.M. wave have a varying frequency after the message signal is mixed into it?
Do you believe in Fourier representation of sinewaves?
AM is a multiplication.
for starters look at your trig identities for product of sines
and that's why sidebands appear at sum and difference frequencies
The original doesn't disappear though
The math is interesting
see https://web.ma.utexas.edu/users/davis/reu/ch2/ch2/AM/am.pdf
However, by adjusting the degree of modulation, ie ratio of carrier to signal that's handed to the multiplier, one can cause some the carrier to remain ,
and they do that in AM radio.
Overmodulation, ie applying too much signal , makes harmonics that show up in other radio bands and that's frowned on.
old jim
Likes sophiecentaur and osilmag
AM is the simplest form of modulating an RF 'carrier wave'. From the well known pictures of an AM signal, you can recognise the 'Envelope' (slow variation) sits on top of the 'Carrier' (fast variation) and it is easy to make sense of that waveform. The early simple Crystal Sets could easily receive AM signals, which was a good reason for using AM, in the early days, In terms of the frequency spectrum, you can say that the carrier itself carries no information. In fact, you do not actually need to transmit the carrier at all and, more than that, you only need to transmit just one of the sidebands. It uses less transmitter power and occupies less bandwidth but the waveform on a 'scope makes no sense at all. A receiver for that signal is much more complicated.
Likes jim hardy
Related to Frequency of Modulated Signal: Carrier vs Message
1. What is a modulated signal?
A modulated signal is a signal that has been altered or manipulated in some way, typically by combining it with another signal. This can be done in order to transmit information or to improve the quality of the signal.
2. What is the difference between a carrier signal and a message signal?
A carrier signal is a high-frequency signal that is used to carry the information of the message signal. The message signal is the signal that contains the actual information being transmitted. The carrier signal is modulated by the message signal in order to transmit the information.
3. How does the frequency of the carrier signal affect the modulated signal?
The frequency of the carrier signal determines the frequency of the modulated signal. When the carrier signal is modulated by the message signal, the resulting modulated signal will have a frequency that is a combination of the two frequencies. This can affect the quality and clarity of the transmitted information.
4. What is the relationship between the frequency of the carrier signal and the bandwidth of the modulated signal?
The bandwidth of the modulated signal is directly related to the frequency of the carrier signal. The higher the frequency of the carrier signal, the wider the bandwidth of the modulated signal will be. This means that a higher frequency carrier signal can transmit more information, but it may also be more susceptible to interference.
5. How is the frequency of a modulated signal measured?
The frequency of a modulated signal is typically measured in Hertz (Hz), which is the unit for frequency. This can be done using specialized equipment such as an oscilloscope or spectrum analyzer. The frequency can also be calculated by measuring the time it takes for the signal to complete one full cycle.
  • Electrical Engineering
  • Other Physics Topics
