Frequency of Reflected light in special relativity
  • Thread starter Thread starter mancity
    Relativity
The discussion centers on the application of the Doppler effect in special relativity, specifically regarding the frequency of reflected light in different frames of reference. There is confusion about why the Doppler effect is applied twice in frame K and whether the signs should be switched since the photon is moving away from the source. Clarification is provided that the correct frequency in frame K can be determined by analyzing the left- and right-going light pulses in the mirror frame. The conversation emphasizes the importance of understanding how frequencies transform between different inertial frames. Overall, the discussion seeks to resolve misunderstandings related to the Doppler effect in the context of special relativity.
mancity
In a reference frame K a photon of frequency f falls normally on a mirror approaching it with relativistic velocity v. Find the momentum imparted to the mirror during the reflection of the photon (a) in the reference frame fixed to the mirror; (b) in the frame K.
f'/f = sqrt((1+(v/c))/(1-(v/c)))
In the. solution attached I'm not too sure why in frame K, we apply the doppler effect twice. Also, since the photon is moving away from the source, shouldn't the signs be switched? Thanks
Your image is hard to read, but you seem to have the right answer in the mirror frame. So in that frame you have left- and right-going light of frequency ##f'##. What frequency will those pulses have in ##K##?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
