Frequency of Undamped Driven Oscillator near Zero
In summary, the conversation discusses the equilibrium that occurs between the spring force and the driving force of a spring-mass system when the frequency of the driving force is very small. This equilibrium can be understood using common sense and does not require knowledge of the equation for amplitude or the differential equation for such a motion. The connection between the small frequency and equilibrium is demonstrated through a practical example of hanging a mass by a spring and exerting an oscillating force on it at different frequencies. When the frequency is near zero, the system remains in equilibrium as the spring hardly "feels" the external force.
Samama Fahim
52
Description of the Problem:
Consider a spring-mass system with spring constant ##k## and mass ##m##. Suppose I apply a force ##F_0 \cos(\omega t)## on the mass, but the frequency ##\omega## is very small, so small that it takes the system, say, a million years to reach a maximum and to go to 0 and so on. This is actually from the following lecture: by Walter Lewin. He argues that if the force goes so slowly then there must be equilibrium at all moment in time between the spring force and the force that we apply, and he does so without using the equation for amplitude of an undamped driven harmonic oscillator or the differential equation for such a motion. We should be able to guess it with common sense.
Equation: $$m\ddot{x} = -kx + F_0 \cos(\omega t)$$
Question: I suppose that there must be a common sense explanation of the driving force and the spring force cancelling each other or almost doing so when the frequency of the driving force is small or near zero. How does a force “going extremely slowly” make the spring force cancel or brings the system into equilibrium at all moments in time? What is the connection between this small frequency and the equilibrium?
I don't know if this agrees with your common sense and/or helps, but here's one practical example that you might consider:
Suppose you are hanging a mass by a spring (or a rubber band or something similar), and the system is at equilibrium, with the spring stretched to whatever (additional) length is needed to counteract the force of gravity on the mass. Now imagine that you exert an oscillating force on the weight, in addition to the "balanced" force of the spring against gravity, by moving the support of the spring (or the rubber band) up and down. If you do this quickly, near the natural oscillating frequency of the spring, you can get the spring-mass system oscillating up and down a huge distance, nearly out of phase with your forcing. On the other hand, if you move the support up and down extremely slowly, the spring-mass hardly even "feels" the springiness. Instead, the mass moves up and down more or less exactly when you move the support up and down. The spring remains nearly in equilibrium at all times because of the huge mismatch in frequency between the spring-mass oscillation frequency and the external force.
Related to Frequency of Undamped Driven Oscillator near Zero
1. What is the frequency of an undamped driven oscillator near zero?
The frequency of an undamped driven oscillator near zero is the natural frequency of the oscillator, which is determined by its mass and stiffness. This frequency is independent of any external forces and remains constant.
2. How does the frequency of an undamped driven oscillator near zero affect its motion?
The frequency of an undamped driven oscillator near zero determines the speed and amplitude of its oscillations. A higher frequency will result in faster and larger oscillations, while a lower frequency will result in slower and smaller oscillations.
3. Can the frequency of an undamped driven oscillator near zero be changed?
No, the frequency of an undamped driven oscillator near zero cannot be changed or adjusted. It is a characteristic property of the oscillator that remains constant as long as its mass and stiffness remain unchanged.
4. What factors can affect the frequency of an undamped driven oscillator near zero?
The frequency of an undamped driven oscillator near zero can be affected by changes in its mass and stiffness. Additionally, external forces or damping can also affect the frequency, but only at higher amplitudes of oscillation.
5. Is the frequency of an undamped driven oscillator near zero the same as its resonant frequency?
No, the frequency of an undamped driven oscillator near zero is not the same as its resonant frequency. The resonant frequency occurs when the external force is in phase with the oscillator's motion, resulting in maximum amplitude. This frequency is slightly higher than the natural frequency of the oscillator near zero.
  • Classical Physics
  • Classical Physics
