Frequency response - Hydraulic network
In summary, the conversation discusses a measured signal of high pressure oscillation in a hydraulic network. After performing a FFT, two dominant frequencies, a and b, were found. Further analysis revealed that the network has two eigenvalues at these frequencies. The question addressed is whether the excitation signal must include these frequencies or if they came from somewhere else initially. The answer is that if the eigenvalues have a magnitude greater than 1, the frequency may have come from a small and undetectable initial disturbance, while if the magnitude is less than 1, the excitation signal must continue to include these frequencies to prevent them from fading away.
LordCatG
Hello everyone,
i have a measured signal of a high pressure oscillation in a hydraulic network. Performing a FFT of said signal shows two dominant frequencies, a and b.
After performing a linear analysis of the hydraulic network i found out that the network has two eigenvalues at those frequenices a and b. If i assume that the hydraulic network is excited at those two eigenvalues and that is what causing the high pressure oscillation, that should mean that excitation signal should have those two frequencies included?
If I understand your question, yes, the frequency must have come from somewhere, at least initially. If the eigenvalues have magnitude greater than 1, the frequency may have only been there for an instant and grown from that. In that case, the initial disturbance may have been very small and undetectable.
If the eigenvalue magnitude is less than 1, then the excitation signal must continue to include some of that frequency in order to keep it from fading away.
Likes berkeman
Related to Frequency response - Hydraulic network
1. What is frequency response in a hydraulic network?
The frequency response of a hydraulic network refers to the relationship between the input frequency and the output amplitude or phase of the system. It describes how the system responds to different frequencies of input signals.
2. Why is frequency response important in hydraulic networks?
Frequency response is important because it allows engineers to analyze and understand the behavior of a hydraulic network under different operating conditions. It helps in designing and optimizing the network for efficient performance.
3. How is frequency response measured in a hydraulic network?
Frequency response can be measured by applying a sinusoidal input signal of varying frequencies to the network and measuring the output response. This can be done using sensors and data acquisition systems.
4. What factors can affect the frequency response of a hydraulic network?
Several factors can affect the frequency response of a hydraulic network, including the physical properties of the fluid, the geometry and size of the network components, and the operating conditions such as flow rate and pressure.
5. How can frequency response be improved in a hydraulic network?
Frequency response can be improved by optimizing the design of the network components, such as using smoother pipes and reducing bends and restrictions. Proper maintenance and regular cleaning of the network can also help improve frequency response.
  • Electrical Engineering
  • Electromagnetism
