Frequency, transverse waves, low-pitch strings
In summary, two identical guitar strings with the same tension are stretched between supports at different distances. The fundamental frequency of the higher-pitched string is 380Hz and the wave speed is 200 m/s. The beat frequency is 4Hz. Using the equations for frequency and wave speed, the length of the lower-pitched string can be calculated to be 0.265957 m, which is 2.80E-3 m longer than the higher-pitched string. This demonstrates the precision required in playing string instruments.
rlc
128
Two identical guitar strings are stretched with the same tension between supports that are not the same distance apart. The fundamental frequency of the higher-pitched string is 380Hz, and the speed of transverse waves in both wires is 200 m/s. How much longer is the lower-pitched string if the beat frequency is 4Hz?
None have worked!
Every yahoo answers solution has not worked for me. Please help!
None meaning which ones ?
Have you attempted a solution ? If so, show your work. Every one of them that didn't work according to you. There must be a way out of this; perhaps one of the dead ends still has an opening somewhere ...
y=y0[sin(2pif1t)+sin(2pif2t)]
Is this the right equation to use?
you need something to connect tension, length and frequency. an equation where some or all appear.
If the beat frequency is 4 Hz, how much is the frequency of the lower-pitched string ?
f = (1/2L)*√(T/μ)
where
  • f is the frequency in hertz (Hz) or cycles per second
  • T is the string tension in gm-cm/s²
  • L is the length of the string in centimeters (cm)
  • μ is the linear density or mass per unit length of the string in gm/cm
  • √(T/μ) is the square root of T divided by μ in seconds
The transverse wave speed v in a flexible string or wife is given by:
v=SQRT(T/u)
where T is tension and u is the mass per unit length of the string
Beats are the difference between two frequencies: ABSOLUTE VALUE OF (f1-f2)
I got it!
f=(1/2L)(transverse wave speed)
380=(1/2L)(200)
L=0.263157 m
Beat frequency=f1-f2
380-4=376 (I know that you can add or subtract the 4, but I went with subtracting first just to try)
376=(1/2L)(200)
L=0.265957
Subtract the two L's:
0.265957-0.263157=2.80E-3 m (which the online homework program says is the right answer)
It wasn't a matter of trial and error: they were specifically asking for the lower-pitched string.
Other than that: good work!
It shows how difficult playing string instruments really is: just a fraction away from the right position and you get undesired beats.
Related to Frequency, transverse waves, low-pitch strings
1. What is frequency?
Frequency refers to the number of cycles or vibrations that occur in a wave per unit of time. In other words, it is the rate at which a wave repeats itself.
2. What are transverse waves?
Transverse waves are a type of wave in which the particles of the medium (such as air or water) vibrate perpendicular to the direction in which the wave is traveling. This creates a series of crests and troughs.
3. How are transverse waves different from longitudinal waves?
In a transverse wave, the particles of the medium move perpendicular to the direction of the wave, while in a longitudinal wave, the particles move parallel to the direction of the wave.
4. What are low-pitch strings?
Low-pitch strings refer to strings on a musical instrument that produce lower frequencies or lower-pitched sounds. These strings are typically thicker and longer compared to high-pitch strings.
5. How does frequency affect the pitch of a string?
The higher the frequency of a string's vibration, the higher the pitch it produces. This is because higher frequencies correspond to faster vibrations and shorter wavelengths, resulting in a higher-pitched sound.
