Frequency, Velocity, Voltage, and Intensity
In summary: Just remember that the retarding voltage is the voltage required to stop the photoemitted electrons from reaching the collector plate. So, if you know the work function and the frequency of the incident light, you can calculate the retarding voltage. And then, using the equation for retarding voltage, you can then calculate the frequency of the incident light.
Illuminitwit
I have to calculate the frequency of incident light shot at a metal plate.
I know the voltage, intensity, and wavelength.
wavelength = velocity/frequency
frequency = velocity/wavelength
voltage = current • resistance
There isn't any specific math involved in this problem, really. I mean, there is because I have the data in a chart that I made after having to experiment with incident light and different kinds of metal plates observing the photoelectric effect. All I need to know in order to finish the table and data by myself is how to get the frequency when I have the intensity, wavelength, and voltage. I don't have a velocity, unless I want to use the velocity of light, which I'm considering. Is it even possible to use the voltage in such calculations to end up at the frequency? I don't think the voltage has a whole lot to do with frequency of incident light. Input is greatly appreciated!
Waiiit... Can't I just use the velocity of light in a vacuum? I mean, I'd have to assume the photoelectric effect in a vacuum, but I guess that'll work... Sorry to waste a post! Unless anyone has any extra advice. Thanks! :)
Current isn't really relevant here, and neither is voltage. You need to figure out the frequency of the incident light required to exceed the work function of the particular metal...
http://en.wikipedia.org/wiki/Photoelectric_effect
Thanks! I didn't think voltage and current stuff was necessary... It isn't really about electrical circuits or anything, sooo...
The three metals I have are Potassium, Calcium, and Uranium... Should I just look up the work function online?
Yes, you should get the work functions for your calculations for the lab report. Also, how were you measuring the photoemissions? Maybe that's where the V and I results come in? Can you describe your lab setup and measuring instruments?
I found a website that has the listed work functions in eV for various metals regarding photoelectric effect. I just have to convert that using 1.6 x 10-19 J•s. So I'm set.
Actually, it's pretty pathetic because it's not a "real" lab. It's considered a virtual simulation online and I have to setup a bunch of different values for wavelength, voltage, et cetera. It's for my Physics class. Sometimes we have real labs and sometimes we're told to go to a certain URL and do an experiment. Basically, I just have controls to change the type of metal, voltage, wavelength, and intensity of the incident light and the photoemissions travel along a little route through this tank and light up a little bulb at the other end (if they reach that far; sometimes the photoemissions just shoot out for a little bit and then go back towards the metal and never reach the bulb). The photoemissions aren't measured, really. I have to calculate them based on what the little simulation window says. I think I have it figured out now, though. Thanks! :)
Yeah, be sure to read and understand the wikipedia link about Photoemission, or your textbook. You should understand what to expect with the online experiments. Like, you should be able to calculate what voltage you need to apply to make the emitted electrons turn around and go back to the emitting plate.
Quiz Question -- how would you calculate that voltage, based on the metal and the incident light's wavelength?
I have no idea... That isn't covered anywhere in my textbook or lessons. I'll see if I can figure it out, though...
The voltage in the simulation is retarding voltage, I think...
According to http://web.mit.edu/zchen/www/PHOTOELECTRICPAPERDRAFT.pdf,
V(retarding) = (hf - phi)/e
KE = hf - phi
phi = work function of the metal
h = Planck's constant
f = frequency
E = hf
e = charge of an electron
"From this equation, we can see that if V is plotted against f, the slope of the line is h/e. Planck's constant h is simply the slope of the Voltage vs. frequency line multiplied by e (charge of an electron)."
KE = hf - phi
f = frequency
E = hf
That's all correct. Hopefully you can figure out why, before you do the lab. It's best to understand the material and have predictions for the results, before actually doing the lab.
FAQ: Frequency, Velocity, Voltage, and Intensity
What is the relationship between frequency and velocity?
Frequency and velocity are inversely related. This means that as the frequency increases, the velocity decreases, and vice versa. In other words, the higher the frequency, the shorter the wavelength and the faster the wave travels, while a lower frequency results in a longer wavelength and slower velocity.
How does voltage affect intensity?
Voltage and intensity are directly proportional. This means that as the voltage increases, the intensity also increases, and vice versa. In other words, the higher the voltage, the greater the energy carried by the wave, resulting in a higher intensity.
What is the difference between voltage and frequency?
Voltage refers to the potential difference between two points in an electrical circuit, while frequency refers to the number of cycles or oscillations per second in a wave. Voltage is measured in volts, while frequency is measured in hertz (Hz).
How does intensity relate to the amplitude of a wave?
Intensity is directly proportional to the square of the amplitude of a wave. This means that as the amplitude increases, the intensity also increases, but at a faster rate. For example, doubling the amplitude of a wave will result in a four times increase in intensity.
How do frequency, velocity, voltage, and intensity affect each other in an electromagnetic wave?
In an electromagnetic wave, frequency, wavelength, and velocity are all interrelated through the equation c = fλ, where c is the speed of light, f is frequency, and λ is wavelength. As for voltage and intensity, voltage affects the energy carried by the wave, and intensity is a measure of that energy. Therefore, all four factors are connected and can influence each other in an electromagnetic wave.
