Fresnel's Biprism Experiment: What Are Virtual Sources?
  • Thread starter gracy
In summary, The Fresnel biprism experiment involves using a prism to create virtual sources of light, from which the refracted rays appear to come from. These virtual sources, S1 and S2, are used to create an interference pattern on the image plane at R. In order for this interference pattern to be visible, the refracting edge of the biprism must be parallel to the slit/source. If not, the wave fronts will not be parallel and the interference pattern will not be visible. This experiment is for interference, not diffraction, and the place where interference occurs is in the region marked by the dashed lines on the image.
  • #36
gracy said:
I don't think it is correct
You've got it correctly --- the text says "two acute angled prisms joined at the bases," and the "bases" count as your black line. It's a confusing explanation of the shape of the prism, and totally irrelevant to the actual discussion of what the prism does. What it's doing in the textbook is a mystery.
  • #37
Bystander said:
The edge that has to be parallel to the slit/source is the edge between the two surfaces that are 179 deg. from each other.
Is this the edge you are talking about.Note that line is going into the page.
  • #38
  • #39
Yes, Ma'am.
  • #40
Bystander said:
. Actually, there are no refracting edges -
Where does refracting edges of both prism(which combine to form biprism) go?
  • #41
Looking at the last attachment, it looks like the cross-section of a roof, yes. The refracting faces of the prism are the two sloped surfaces of the "roof."
Likes gracy
  • #42
gracy said:
This
Fresnel's biprism experiment is for interference not diffraction ,right?
Try to avoid classifying in that way. It's all diffraction. Interference is just a simplification in which you can identify isolated sources rather than continuous ones. The calculations are just easier for Interference situations.
BTW, there is confusion with the term "diffraction grating" which is usually explained in terms of interference (Summation) rather than diffraction (Integration). You can't win, if you get hung up on classification. :)
Likes gracy
