Friction coefficient and the force on a syringe plunger
In summary, the conversation discusses measuring the coefficient and force of friction of rubber inside a syringe, and the challenges of doing so without a dynamometer. It is suggested to use a lever or weight instead of a thumb, and to consider the difference between static and dynamic friction. The contents of the syringe, which is air, are also discussed. Additionally, the purpose and context of the experiment are questioned, along with the importance of the type of fluid inside the syringe.
Huger
New poster has been reminded to post the Relevant Equations and show their work on schoolwork problems
I need to conduct an experiment and measure how what is the coefficient and force of friction of the rubber that pushes down along the edge inside the syringe. The thing is I can’t use a dynamometer.
Hello Huger, ##\qquad## :welcome: ##\qquad## !
Voluntary restriction ?
Alternatively you could use a lever or a weight instead of your thumb
Are you aware of the difference between static friction and dynamic friction ?
And: what's in the syringe ? air, water, glycerine ?
Likes hmmm27
BvU said:
Hello Huger, ##\qquad## :welcome: ##\qquad## !Voluntary restriction ?
It’s air inside
Welcome to the PF. :smile:
Huger said:
Homework Equations: ?
Why have you not posted the obvious equations that relate to frictional forces?
And are you to assume the end of the syringe is open? Does it have a needle on it? If so, what gauge needle and why does that matter?
Huger said:
It’s air inside
When not using a dynamometer, the tricky part is only measuring the frictional force, not including any additional force leading to an acceleration. But since you want kinetic friction, there must be motion.
Coefficient is rather tougher. How are you going to assess the normal force (per unit of arc)? If I had this problem to solve in the real world, I would measure the coefficient of friction between the two materials in a different set up (where the normal force is known, say a block sliding on a glass plate, with a weight on the block) then, from the force needed to push the syringe, deduce the normal force.
Fwiw, if you only wanted to find the normal force you could set up the syringe and the block on a plate in a back-to-back arrangement. Push the two together and see which slides. Adjust the weight on the block until it is borderline which slides.
@Huger : can you enlighten us about purpose and context ?
And: why air ?
And: why air ?
Presumably it is air in order to avoid complications arising from back-pressure from the fluid. However, it might matter whether the sides are dry or wet.
Related to Friction coefficient and the force on a syringe plunger
1. What is the friction coefficient?
The friction coefficient is a dimensionless quantity that represents the amount of resistance between two surfaces in contact. It is a measure of how difficult it is to slide one surface over the other.
2. How is the friction coefficient determined?
The friction coefficient can be determined experimentally by measuring the force required to move one surface over the other. It can also be calculated using the formula μ = F/N, where μ is the friction coefficient, F is the force of friction, and N is the normal force between the two surfaces.
3. What factors affect the friction coefficient?
The friction coefficient can be affected by various factors such as the type of surfaces in contact, the roughness of the surfaces, the amount of force pushing the surfaces together, and the presence of any lubricants.
4. How does the friction coefficient affect the force on a syringe plunger?
The friction coefficient plays a crucial role in determining the force required to push a syringe plunger. A higher friction coefficient means more resistance between the plunger and the inside of the syringe, resulting in a greater force needed to move the plunger.
5. Can the friction coefficient be reduced to decrease the force on a syringe plunger?
Yes, the friction coefficient can be reduced by applying a lubricant to the inside of the syringe. This will reduce the resistance and make it easier to push the plunger, therefore decreasing the force required.
  • Mechanical Engineering
