Friction - Influence of mass with elastic materials
In summary, the floor with the polyurethane top coat has a larger coefficient of friction than the other floors.
YeeHaa
28
Hi,
I'm doing some research on friction, and I did some tests with 4 different types of floor.
Now the first of these four floors is a sport surface (it has a polyurethane top coat), the second one is a floor-tile (with fabric on top), the third one a piece of foam and the fourth a piece of wood.
All of these materials were tested against metal.
Now I tested every floor with 3 different weights, and took some measurements (measured the normal force and friction force).
When I look at the Coefficient of Friction, it seems that for the first two floors (sport surface and floor tile), the Coefficient of Friction is LARGER when the weight is SMALLER. As soon as I increase the weight (2nd and 3rd weight), the Coefficient of Friction stays the same (it's the same for both weights).
Could this have to do with Amonton's Second Law? Maybe less weight means the surface deformes little.. (but in my eyes this would mean that friction should be lower), and with a lot of weight more of the surface at microscopic level touches the metal?
Some numbers:
Sport surface - metal:
Weight 1: (about 9 kg): CoF = 0.27
Weight 2: (about 15 kg): CoF = 0.19 (+/-)
Weight 3: (about 25 kg): CoF = 0.19 (+/-)
Floor tile - metal (same as sport surface, guess that's coincidence)
Foam - metal:
Weight 1: (about 9 kg): CoF = 0.42
Weight 2: (about 15 kg): CoF = 0.43 (+/-)
Weight 3: (about 25 kg): CoF = 0.41 (+/-)
Wood - metal:
Weight 1: (about 9 kg): CoF = 0.11
Weight 2: (about 15 kg): CoF = 0.12(+/-)
Weight 3: (about 25 kg): CoF = 0.11(+/-)
Anyone?
You haven't given enough about the experimental setup to even speculate about the cause. Some basic missing facts are
* Were you measuring static or dynamic friction?
* What was the geometry of the moving object and how was it loaded with weights? (we don't know if the pressure between the surfaces was uniform across the whole contact area or not).
* How did you apply the force to overcome friction? (i.e. where did you apply the force to the object and were you pushing or pulling? Is it possible it was trying to tip over and "dig into" the floor before it started moving?
But there's no guarantee you will get any useful answers even with that information. The experiment is probably too uncontrolled to "explain" anything in much detail. When you say "a sports floor with a polyurethane top coat" we don't know whether it is newly laid or 10 years old, how smooth it is, how clean it is, whether it has been polished with anything that might act as a lubricant or an adhesive, etc, etc...
If you really want to figure out "exactly" what is happening, you have to control all those types of factors, and/or vary them to investigate what effect they might have.
Related to Friction - Influence of mass with elastic materials
1. How does the mass of an object affect friction in elastic materials?
The mass of an object does not directly affect friction in elastic materials. Friction is primarily influenced by the surface properties of the materials in contact and the force applied between them. However, a heavier object may exert more force on the surface, increasing the friction.
2. What role does elasticity play in friction?
Elasticity can affect friction in two ways. First, elastic materials can deform under pressure, creating more surface contact with the other material and increasing the friction. Second, the rebound of the elastic material can help reduce friction by absorbing and releasing energy as the two surfaces move against each other.
3. How does friction differ in elastic materials compared to non-elastic materials?
Friction in elastic materials tends to be more complex and variable compared to non-elastic materials. The deformation and rebound of the elastic material can create different surface properties and increase or decrease the friction. Additionally, the elastic material may wear down or change over time, further altering the friction.
4. Can friction in elastic materials be reduced or eliminated?
It is difficult to completely eliminate friction in any material, including elastic materials. However, certain factors can reduce the friction, such as using lubricants or reducing the force applied between the two surfaces. Additionally, using materials with lower coefficients of friction can also help reduce the overall friction.
5. How is friction in elastic materials measured and studied?
Friction in elastic materials can be measured using various methods, such as force sensors, surface analysis tools, and tribometers. These tools can help scientists study the effects of different materials, forces, and surface properties on friction in elastic materials. Additionally, computer simulations and mathematical models can also be used to study and predict friction in elastic materials.
9K
