Friction necessary for planet formation?
In summary, friction is important in the formation of stars and planets because it causes energy and angular momentum to be ejected from the system.
AxelBoldt
For a gas and dust cloud to collapse under gravity to form a star and planets, is the concept of friction important at all?
In other words: let's consider a large number of billiard balls, no internal degrees of freedom, participating in completely elastic collisions, with random initial conditions, subject only to their own gravity. Will they eventually clump together into one big "star" and several smaller "planets" surrounding the star?
Astronomy news on Phys.org
Axel, I only have a minute (have to go out) so I hope other people will help answer. Consider ways that energy and angular momentum could be ejected from the system.
Some energy can be radiated. When things crash and turn red hot you get rid of some energy by thermal radiation. Also debris may acquire escape speed and leave the system taking unwanted energy with it.
Also there is the gravitational slingshot thing that happens. One billiard has a close encounter with another. One can pick up energy and angular momentum and be flung clear out of the system, the other perhaps is slowed down by the interaction.
I think your conjecture is right that they will eventually clump into a central body and some smaller planets----but there will also be billiards that you didn't mention that were ejected from the system, taking surplus gravitational energy.
Agreed, there will be a significant portion of matter that is slingshotted out of the system. Also, the collisions can't be elastic or else things wouldn't end up sticking together! What will happen is there will be two "states" if you will, for the original particles:
1. Initial velocity and position lead to an unstable orbit. This situation has two possibilities:
a. The ball is ejected out of the system after it falls towards the gravitationally forming center.
b. The ball collides with the gravitationally forming center and merges with it.
2. Initial velocity and position lead to a stable orbit. This situation is relatively rare, but when it does happen the stable orbiting "ball" accretes matter until it grows to planetary size.
I should think friction is important in this model in the sense that depending on the density of the gas and dust cloud, collisions which heat matter cause the particles to lose rotational kinetic energy and fall into the center.
Yes, that's the heart of my problem. Assuming totally elastic collisions, the balls will never "stick together", but there could still emerge regions of very high density, where balls are kicking each other like crazy, with the whole region being held together by gravity. And these are the regions I would call "star" and "planets". Possibly though the most likely outcome in this scenario is that almost all balls will eventually leave the system?
Does anyone know any simulators I could play with?
Related to Friction necessary for planet formation?
1. What is friction necessary for planet formation?
Friction is a force that opposes motion and is necessary for planet formation because it allows particles and materials in a protoplanetary disk to collide and stick together, forming larger bodies such as planets.
2. How does friction help in the process of planet formation?
Friction helps in the process of planet formation by causing particles in a protoplanetary disk to lose energy and spiral inward towards the central star, creating areas of higher density where planets can form. It also helps to slow down the rotation of the disk, allowing materials to clump together and form larger bodies.
3. What role does friction play in the accretion of planetesimals?
Friction plays a crucial role in the accretion of planetesimals, which are small bodies that eventually form planets. As these bodies collide and stick together, friction causes them to lose energy and merge into larger bodies, eventually forming planets.
4. Can friction also hinder planet formation?
Yes, friction can also hinder planet formation in some cases. If the protoplanetary disk is too hot, the particles may move too quickly and collide with too much force, causing them to break apart rather than stick together. This can hinder the formation of larger bodies and ultimately prevent planet formation.
5. Are there any other factors that contribute to planet formation besides friction?
Yes, there are other factors that contribute to planet formation besides friction. These include the composition of the protoplanetary disk, the temperature and pressure within the disk, and the gravitational forces between particles. All of these factors work together in the process of planet formation.
  • Astronomy and Astrophysics
