Friction of a sliding box on a slope
In summary, the problem involves a loaded penguin sled on an inclined plane with coefficients of static and kinetic friction. It asks for the minimum force required to prevent the sled from slipping down the plane, to start the sled moving up the plane, and to keep the sled moving up the plane at a constant velocity. The correct answers are 4.646 N, 14.276 N, and 7.663 N for parts a, b, and c respectively.
J-dizzal
394
A loaded penguin sled weighing 75 N rests on a plane inclined at angle θ = 21° to the horizontal (see the figure). Between the sled and the plane, the coefficient of static friction is 0.30, and the coefficient of kinetic friction is 0.18. (a) What is the minimum magnitude of the force F , parallel to the plane, that will prevent the sled from slipping down the plane? (b) What is the minimum magnitude F that will start the sled moving up the plane? (c) What value of F is required to move the sled up the plane at constant velocity?
http://edugen.wileyplus.com/edugen/courses/crs7165/art/qb/qu/c06/fig06_29.gif
fss Fn is the magnitude of the maximum static force.
fkk Fn is the kinetic friction force.
http://s1294.photobucket.com/user/jhoversten/media/20150626_193750_zpsvqv6akeu.jpg.html
i can see why my attempt at solving a is not working. thanks[/B]
You did it right, except you miscalculated FT and FN
The angle is 21 degrees not 20 degrees.
opps thanks
im getting 4.646 N but this is still wrong.
That's not what I get. Did you correct both FT and FN?
oh yea i forgot to correct the right side of my equation. thanks
for part b; i set up and equation identical to the equation in part a except is used μk and got an answer 14.276 N. And this would be the force required to start the sled moving up the ramp after the static force was applied. I am not sure how to set it up
i added the force from part a to part b and that was not good.
i initiall thought it would be the same answer as part a, because once the block is broken free from gravitational forces and static frictional force it should be ready to move with any increase in force applied right?
μk does not come into play yet. You want to find the force F which puts it on the verge of slipping upwards, so you will still want to use μs
It's similar to part a but it's not the same:
Friction opposes the motion of the block; in part a, the block was about slip downwards. In part b, the block is about to slip upwards.
Nathanael said:
μk does not come into play yet. You want to find the force F which puts it on the verge of slipping upwards, so you will still want to use μsIt's similar to part a but it's not the same:
oh right friction is a non conservative force so it works in both directions.
Thanks Nathanael
No problem
Related to Friction of a sliding box on a slope
1. What is friction?
Friction is a force that resists the relative motion between two surfaces in contact. It is caused by the microscopic irregularities on the surfaces that interlock and create resistance.
2. How does friction affect a sliding box on a slope?
Friction can either help or hinder the motion of a sliding box on a slope. If the box is moving upwards, friction acts against the motion and makes it harder for the box to move. If the box is moving downwards, friction acts in the same direction and helps to slow down the box.
3. What factors affect the friction of a sliding box on a slope?
The amount of friction between the box and the slope depends on the nature of the surfaces in contact, the weight of the box, and the angle of the slope. Rougher surfaces, heavier boxes, and steeper slopes will result in more friction.
4. How can the friction of a sliding box on a slope be reduced?
There are a few ways to reduce the friction of a sliding box on a slope. One way is to use a lubricant, such as oil or grease, to reduce the contact between the surfaces. Another way is to decrease the weight of the box or use a smoother surface for the box to slide on.
5. How is the coefficient of friction calculated for a sliding box on a slope?
The coefficient of friction is a value that represents the relationship between the force of friction and the normal force (force perpendicular to the surface). It can be calculated by dividing the force of friction by the normal force.
