Friction problem with hardly any variables given
In summary, on level ground, the minimum stopping distance is 60 meters. However, if the car is on an incline, the stopping distance will be shorter due to the force of gravity.
mooney82
The minimum stopping distance for a car from an initial 100km/h is 60 m on level ground. What is the stopping distance when it moves (a) down a 10 degree incline; (b) up a 10 degree incline? Assume the initial speed and the surface are unchanged.
Fk=uk*N
I have no clue how to solve this. There is no uk value given, no mass given, or a force. I can find the acceleration of the car on a level surface (-6.431) but not sure how to find force without mass, how to find the N value without the mass or the uk value.
If that is all you are given, maybe try using the kinematic equations on the angle of the plane. What I'm saying is find the component of acceleration due to gravity in the plane of the inclined plane and try manipulating the two accelerations to get a correct stopping distance.
But without the mass you can't find out the acceleration due to gravity.
Without the force you can't find the mass.
Are you sure that the question wants a quantitative answer and not a qualitative answer?
Actually, try this. When the car is on the incline plane, there is a force that wants to pull the car down the plane and that force is mgsin(theta). However, the car is also stopping or decelerating. We found that on flat ground, a=-6.43. So on the inclined plane to find the component along the plane, we must multiply by cos(theta). The force of this will be the cars mass, m, times the acceleration, -6.43cos(theta). Therefore, your net force will be mgsin(theta)-6.43m=ma. You can then solve this for a and the m's will cancel. Then plugging in this a into the kinematic equation, you can find the stopping distance. Understand?
Ya, I think so. I'll try it tomorrow, thanks a lot!
FAQ: Friction problem with hardly any variables given
What is friction and why is it important to study?
Friction is a force that resists the motion of objects when they come into contact with each other. It is important to study because it affects the movement of objects and is essential for understanding and predicting the behavior of various systems, such as machines and vehicles.
What are the factors that affect friction?
The factors that affect friction include the nature of the surfaces in contact, the force pushing the surfaces together, and the presence of any lubricants or contaminants.
What is the difference between static and kinetic friction?
Static friction is the force that resists the initial motion of an object, while kinetic friction is the force that acts on an object in motion. The force of static friction is typically greater than the force of kinetic friction.
How is the coefficient of friction determined?
The coefficient of friction is determined by dividing the force of friction by the normal force (the force pushing the two surfaces together). This value is dependent on the materials in contact and the surface conditions.
What are some practical applications of studying friction?
The study of friction has many practical applications, including designing and improving machines, predicting and preventing wear and tear on surfaces, and understanding the behavior of various modes of transportation, such as cars and airplanes.
