Friction with moving block question
In summary, the conversation discusses a drawing of a large cube being accelerated across a frictionless surface by a horizontal force and a smaller cube in contact with it. The coefficient of static friction between the cubes is given as 0.71 and the question is to find the minimum magnitude of the force P required to prevent the smaller cube from sliding downward. The conversation also includes a hint on how to approach the problem.
ethrust2
The drawing shows a large cube (mass = 49 kg) being accelerated across a horizontal frictionless surface by a horizontal force P. A small cube (mass = 4.6 kg) is in contact with the front surface of the large cube and will slide downward unless P is sufficiently large. The coefficient of static friction between the cubes is 0.71. What is the smallest magnitude that P can have in order to keep the small cube from sliding downward?
http://www.flickr.com/photos/42276194@N04/3981264713/
Anyone have any idea?
I tried both normal forces multiplied by the static friction coefficient.
Welcome to PF!
Hi ethrust2! Welcome to PF! :wink:
Hint: for a particular P, what is the acceleration of the small block?
and so what is the reaction force on the small block? :smile:
I also tried using the acceleration of the large cube and setting it equal to the force of P.
I would approach this problem by first identifying the relevant equations and variables involved. In this case, we have the force P, the masses of the two cubes, and the coefficient of static friction between them. The goal is to determine the minimum value of P needed to prevent the smaller cube from sliding downward.
To start, we can use Newton's second law of motion, which states that the net force on an object is equal to its mass multiplied by its acceleration. In this case, we can apply this equation to the larger cube, since it is the one being accelerated by the force P. This gives us:
net force = mass x acceleration
Since the surface is frictionless, the only force acting on the larger cube is the force P. Therefore, we can rewrite the equation as:
P = mass x acceleration
Next, we need to determine the acceleration of the larger cube. We can use the formula for acceleration, which is the change in velocity divided by the change in time. In this case, the larger cube starts from rest and reaches a final velocity in a given time. Therefore, we can use the equation:
acceleration = (final velocity - initial velocity) / time
Since the larger cube is moving horizontally, we can assume that its final velocity is the same as its initial velocity (since it doesn't change direction). Therefore, we can simplify the equation to:
acceleration = velocity / time
Now, we can use the information given in the problem to solve for the acceleration of the larger cube. The problem states that the larger cube has a mass of 49 kg and is being accelerated by the force P. Therefore, we can use the equation:
to rewrite the acceleration as:
acceleration = P / mass
Now, we can substitute this into our previous equation for acceleration to get:
P = velocity / time x P / mass
Next, we need to determine the velocity and time values. The problem does not give us any specific values, so we can use general variables v for velocity and t for time. This gives us:
P = v / t x P / mass
Now, we can use the formula for the coefficient of static friction to determine the maximum force that can be applied before the smaller cube starts to slide downward. The formula is:
maximum force = coefficient of static friction
FAQ: Friction with moving block question
1. What is friction?
Friction is a force that resists the relative motion or tendency of motion between two surfaces in contact with each other.
2. How does friction affect a moving block?
Friction between the moving block and its supporting surface can slow down or stop the block's motion, depending on the direction of the force and the coefficient of friction between the surfaces.
3. What factors influence the amount of friction on a moving block?
The amount of friction on a moving block depends on the types of surfaces in contact, the force pressing the surfaces together, and the roughness of the surfaces.
4. Can friction be completely eliminated on a moving block?
No, friction cannot be completely eliminated on a moving block. Even with very smooth surfaces and minimal force, there will still be some friction present.
5. How can the effects of friction be reduced on a moving block?
The effects of friction can be reduced on a moving block by using lubricants, such as oil or grease, to create a slippery layer between the surfaces in contact.
