Frictional Force vs normal force
In summary, the frictional force on the block is 10 N due to the object being in static equilibrium with the applied force of 10 N. This is because the frictional force must not exceed the coefficient of static friction (0.5) times the normal force (50 N). Therefore, the frictional force is equal to the applied force, resulting in a frictional force of 10 N.
Dalip Saini
A 10 N horizontal force is applied to a 50 N block initially at rest on a rough horizontal surface. If the coefficient of static friction is 0.5 and the coefficient of kinetic friction is 0.4, then the frictional force on the block is
  • A
    10 N
  • B
    20 N
  • C
  • 0 N
  • D
  • 25 N
Frictional force = (coefficent of static friction)(normal force)
Normal Force = mass x gravity = 50 N due to Newtons second law
Frictional force = 50 * 0.4 = 20 N but the answer is 10 N and I don't understand why
With regard to static friction, the frictional force is not always equal to the coefficient of static friction times the normal force. If the frictional force does not exceed (coefficient of static friction)(normal force), then the object will not slide on the surface. In your case it doesn't, so no sliding will occur, and the body will be in static equilibrium, with the frictional force being in equilibrium with the 10 N applied force. In general, for static friction,
(frictional force) ≤ (coefficient of friction)(normal force)Chet
okay thank you so much
Related to Frictional Force vs normal force
What is the difference between frictional force and normal force?
Frictional force is a force that opposes the motion of an object, while normal force is a force that acts perpendicular to the surface of an object. In other words, frictional force acts parallel to the surface, while normal force acts perpendicular to the surface.
How is frictional force related to the normal force?
Frictional force is directly proportional to the normal force. This means that as the normal force increases, the frictional force also increases. Similarly, when the normal force decreases, the frictional force also decreases.
What are some examples of frictional force and normal force in everyday life?
Frictional force can be observed when walking on a rough surface, when using brakes on a bicycle or car, or when rubbing your hands together. Normal force can be experienced when standing on the ground, when sitting on a chair, or when holding an object in your hand.
How does the magnitude of frictional force and normal force affect the motion of an object?
The magnitude of frictional force can either help or hinder the motion of an object. For example, in the case of a car, frictional force helps slow down the car when brakes are applied. On the other hand, normal force is necessary for an object to maintain its position or to resist external forces that may cause it to move.
How do different surfaces and materials affect the frictional force and normal force?
The type of surface and materials involved can greatly affect the magnitude of frictional force and normal force. For example, smooth surfaces typically have less frictional force compared to rough surfaces. Similarly, the weight and texture of an object can also impact the normal force acting on it.
