Frictional Torque of a Spinning Top
I was thinking of testing out different shapes by 3D printing them.In summary, the conversation is about designing a spinning top that can spin for as long as possible. The person has been experimenting with different materials and designs and has managed to get a top to spin for 20 minutes with the assistance of an electric starter. They are seeking help in calculating the frictional torque after the top is released and have made some assumptions about the top's components and initial velocity. They also mention wanting to use the same constants for comparison with other designs, and are not too concerned about finding exact values. The other person agrees with the calculations and suggests considering drag and using Hertz contact stress theory to find the most aerodynamic shape. They also suggest
MR SPIN
Hello,
This is not a home work question but this seems to be the most appropriate spot to post this. I am trying to design a top that will spin for as long as possible. (Google "spinning top" if you're not sure what I a mean by a top) . I've been experimenting with different materials and top designs and have managed to get a top to spin for about 20 min with the assistance of electric starter.
I need help calculating the frictional torque after the top is released . Can you check my analysis and tell me if I am right?
Assumptions
Top initial av = 125.6 rad/sec
Air resistance is zero
The top has 2 main parts
1 - Metal flywheel
2 - "non flywheel" part of the top (inside section, stem, pivot ball have an immaterial mass and MOI.)
TOP 1
Flywheel
Stainless Steel Hoop
Density 8 g/cc
Outside Diameter 62 mm
Wall thickness 1 mm
Outside Radius 31 mm
Inside Radius 30 mm
Height 13 mm
vol = 2.5 cc
mass = 20 gI = 1/2 m (r1^2 + r2^2)
= .5 * 0.02 kg * (.031^2 + 0.030^2)
= 1.85 x 10 ^ -5
The top spins on a 4mm diameter tungsten ball attached (fixed, glued on) to the bottom of a straight stem that goes directly through the central axis of the flywheel. The top is spinning on glass surface with a 0.2 coefficient of friction. The estimated radius of the contact area (spherical cap) the ball makes with glass is 0.2 mm.
Here's how I got 0.2mm:
Base surface area (contact area) of 4 mm ball
= pi * h (2r-h)
= 3.14159 * 0.01 mm * ( 2*2mm - 0.01mm)
= 0.125349
I just picked h= 0.01 mm out the air (who know how much of the tip actually contacts the surface, h =0.01 is a "constant" I will use when comparing designs)
A=pi*r ^2
r = sqrt (0.125349/pi)
= 0.2 mmfrictional torque = 2/3 * mass * g * cof * r (contact radius)
= 2/3 * 0.020 g * 9.8 * 0.2 * 0.0002 m
= 5.2 x 10^-6
spin time = 125.6 (I/torque)
= 125.6 (1.85 x 10 ^ -5 / 5.2 x 10^-6)
= 447 secI am not too concerned about finding the exact COF, friction contact surface area , spin times. I will
use COF and contact surface area as the same "constants" in all my designs. I am more concerned with
the making comparisions with other designs on a relative basis. Eg top design 1 spins for x sec, top
design 2 spins for 2x seconds. I know air drag/resistance plays a very large role in overall spin
times but for now I just want to isolate the impact of tip friction only.
Am I doing this correctly? If I am I have some very interesting results I would like to get your
opinion on. Eg It does not matter what the flywheel height is. It could be 1000 mm or 1 mm , the
theoretical spin time with always be the same. Also it does not matter what the density of the material
is , the spin time will always be the same as long the the hoop dimensions stay constant. You could make
the top out of tungsten or wood and still get the same theoretical spin time.
Bottom line: Are the above calculations correct?
Looks good to me.
MR SPIN said:
it does not matter what the density of the material is
Yes, until you consider drag.
haruspex said:
Looks good to me.
Thanks for the confirmation. Will work next on a drag analysis . Appears drag consists of 2 main components 1 ) pressure drag 2) viscous drag. Off to the books.
Your 4 mm ball looks rather large to me. By reducing the ball diameter, you automatically reduce the friction radius. This was commonly done in the watch industry using pointed pivots running in pockets in jewel bearings. You can do a lot better, I suspect, than the 4 mm ball.
Yes, my next top will have a smaller ball. My analysis shows a 2mm ball increases spin time by about 40% and 1 mm ball almost doubles the spins time (in theory). Will try 2 mm ball in my next design.
Have you applied Hertz contact stress theory to look at the size of the contact zone? This would also give you the pressure distribution over the contact zone and therefore enable you to calculate the friction torque, at least numerically if not in closed form. I am certain that the smaller you can make the tip (and thus the smaller the contact zone), the lower the friction torque will be.
I googled "Hertz contact stress theory" and definitely looks interesting but way over my head. My next big concern is finding the most aerodynamic shape.
Related to Frictional Torque of a Spinning Top
What is frictional torque?
Frictional torque is the force that resists the rotation of a spinning top. It is caused by the contact between the top and the surface it is spinning on.
How is frictional torque calculated?
Frictional torque can be calculated by multiplying the coefficient of friction between the top and the surface by the normal force and the radius of the top. The formula is τ = μ * F * r, where τ is the frictional torque, μ is the coefficient of friction, F is the normal force, and r is the radius of the top.
What factors affect frictional torque?
The coefficient of friction, the normal force, and the radius of the top are the main factors that affect frictional torque. Other factors that can influence it include the surface texture and the speed of the top's rotation.
How does frictional torque impact the spinning top's rotation?
Frictional torque slows down the rotation of the spinning top, causing it to eventually come to a stop. The higher the frictional torque, the faster the top will stop spinning.
How can frictional torque be reduced?
To reduce frictional torque, one can use a smoother surface for the top to spin on, decrease the normal force by using a lighter top, or decrease the rotation speed of the top. Using a lubricant can also help reduce frictional torque.
  • Mechanics
  • Mechanics
