Frictionless pully acceleration
In summary, the conversation discusses a system involving two masses, M1 and M2, connected by a string over a frictionless pulley. The general expression for the acceleration of both masses is discussed, and it is argued that the force acting on M1 must be greater than the mass of M2 in order for M1 to accelerate forward. The correct setup for the ƩF=ma equations for both masses is also discussed.
CollegeStudent
109
M1 is on a frictionless flat horizontal surface. It is attached to M2 by a string, which hangs freely from the string which passes over a frictionless pulley of negligible mass. Find a general expression for the acceleration of both M1 and M2. Look at your result and argue that it should be correct.
I'm not really sure how to word this but:
If the mass of M2 is...say .050kg , the force acting on M2 would be the mass of it * gravity. In order to accelerate, M1 would need to have a force act on it that is greater than the mass of M2. If the force pushing M1 was = to the mass of M2 , then M1 would be static.
Is this correct?
A force cannot be compared (as in greater, less than) to a mass.
Let the tension in the string be T. List the forces acting on each mass and write out the appropriate ƩF=ma equations for each.
Okay...so for the hanging M2 we have
ƩF=ma
ƩF=m * g
And M1 has some type of force acting on it that keeps it from rolling back towards M2. (Gravity and normal force are excluded here because there is no vertical acceleration of M1)
That force would be the opposite of the force acting on M2.
That means that the tension of the string connecting the 2...would equal the force pushing M1 foward.
So if tension = the force on M1...and the force of M1 is equal and opposite to the force acting on M2
ƩF = T = mass of M2 * g
If that's true...that would make M1 be static and not moving foward nor backwards...so in order for M1 to accelerate foward...the magnitude of the force acting on M1 would have to be GREATER than the mass of M2 * g.
Does THIS look any better?
ƩF=ma
ƩF=m * g
No, mg is a force, so it's one part of the ƩF. Let's say the mass of M2 is m2, so the gravitational force here is m2g. What else is in ƩF?
Suppose the system accelerates at rate a; so M2 accelerates down at rate a (while M1 accelerates towards the pulley at the same rate). So the RHS is just m2a.
What makes you think that? It will accelerate towards the pulley - there's nothing holding it back.
No, you must not assume T = m2g. If that were true, there'd be no net force on M2, so no acceleration.
And that isn't the same thing as saying the acceleration is going to be the opposite of the mass of M2 times gravity?
Right, sorry I wasn't clear...I meant there has to be some force acting on M1 to prevent it from rolling back. Otherwise, yes it will accelerate towards the pulley.
Ahh okay...so when tension = the force acting on M2..the 2 objects are static? It just throws me off because...if you have a force reader, (those things you can attach to a string and pull and see the amount of force being applied) wouldn't the forces be equal and opposite? Thus making the tension = to that force?
Then again that makes the string static...okay, back to the original problem...so in order for M1 to accelerate either forwards or backwards the force acting one one side, either M1 or M2 would have to be greater than the force acting on the opposing object?
Draw two free body diagrams. The first "body" will be M1, the only force acting on M1 is tension towards the pully. Your second "body" is M2. There are two forces acting on M2, Tension pulling up, and the force due to gravity pulling down.
Now set up equations for both Free body diagrams using Newtons 2nd law. ƩF=ma
Related to Frictionless pully acceleration
What is a frictionless pulley?
A frictionless pulley is a device used to change the direction of a force. It consists of a grooved wheel and a rope or belt that runs along the groove. The pulley is designed to have minimal friction, allowing the rope or belt to move smoothly and easily.
How does a frictionless pulley affect acceleration?
A frictionless pulley has no effect on the acceleration of an object. This is because the pulley only changes the direction of the force being applied, not the magnitude of the force. Therefore, the acceleration of an object connected to a frictionless pulley will be the same as if there were no pulley present.
What is the formula for calculating acceleration in a frictionless pulley system?
The formula for calculating acceleration in a frictionless pulley system is a = (F - T) / m, where a is acceleration, F is the applied force, T is the tension in the rope or belt, and m is the mass of the object being moved.
How does the number of pulleys in a system affect acceleration?
The number of pulleys in a system does not affect the acceleration of an object. As long as the pulleys are frictionless, the force and tension will be distributed equally among all the pulleys, resulting in the same acceleration as if there were only one pulley.
What are the advantages of using a frictionless pulley system?
The main advantage of using a frictionless pulley system is that it reduces the amount of force required to move an object. This makes it easier to lift heavy objects or move them over longer distances. Additionally, frictionless pulleys can also be used to change the direction of a force, making them useful in a variety of scientific and engineering applications.
