Friedmann Equation - Positive Curvature
In summary, the Friedmann Equation without the cosmological constant can be written as $$H^2=\frac {8πρG} {3}-\frac {1} {a^2(t)}$$ for ##Ω>1##, which results in a positive curvature universe. In a matter dominant universe, the equation can be simplified to $$H^2=\frac {1} {a^3(t)}-\frac {1} {a^2(t)}$$. The proper distance is proportional to a(t), ##D=a(t)Δx##, so when ##a(t)## is smaller than ##1##, it means the universe is collapsing. However, in this model, ##a(t)
Arman777
Insights Author
193
Friedmann Equation without the cosmological constant can be written as;
for ##Ω>1## (which in this case we get a positive curvature universe), and for a matter dominant universe;
$$ρ=\frac {1} {a^3(t)}$$
so in the simplest form the Friedmann equation becomes;
For a(t) larger than 1. The equations becomes negative but I remember that
Proper distance is proportional to a(t), ##D=a(t)Δx## so when ##a(t)## is smaller then ##1## it means universe collapses. In this case how it expends in the first place ?
##a(t)## is a function of ##t## so in this sense even its get smaller its possible that to get expand and then collapse I think but how can I find it ?
Likes madison wolf
Space news on Phys.org
Why did you skip the matter term for the collapsing universe? It is still there, and larger than the other term.
a(t) is always smaller than 1. You used this already to determine that the matter term is larger in the expansion phase.
I understabd that my condition happenz for a(t) is larger than 1. But in early times universe was expanding so hows that possible that a(t) is smaller than 1 and universe still expands ?
I didnt quite understand the general solution for ##k=1##.
We have;
$$H^2=\frac {8πGρ} {3}-\frac {1} {a^2(t)}$$
And
$$\frac {dρ} {dt}+3Hρ=0$$
Is it enough to find a solution ?
See here, Matter Only (k = 1).
Likes Arman777
##a(θ)## comes from the FLRW metric ?
What does "expand" mean?
It can still expand but the speed of expansion can slow down or derivative of it
Your statement that when ##a(t)## is smaller than ##1## the universe collapses is incorrect. In this model, ##a(t) \le 1## always. As long as ##a(t) < 1##, then ##1/a^3 > 1/a^2##, so that the right hand side is positive. Early on, ##H > 0##. As the universe expands, it reaches a point where the matter term and the curvature term are equal, so that ##H=0##. Then the universe recollapses after that point. ##H^2 \ge 0## always. It has to: otherwise the rate of expansion would be an imaginary number. You can verify this behavior by looking at the second Friedmann equation and considering appropriate initial conditions.
Likes mfb
So the inital conditions are
##\ddot a(t)<0## and ##\dot a(t)>0## and ##H=\frac {\dot a(t)} {a(t)}>0##
at some point it will be,
##\ddot a(t)<0## and ##\dot a(t)=0##. So does ##H=\frac {\dot a(t)} {a(t)}=0##
Then since ##\ddot a(t)<0##;
##\dot a(t)<0##, So does ##H=\frac {\dot a(t)} {a(t)}<0##
But in all of these cases ##H^2≥0##
Is this true ?
If its true then what will be the value of ##a(t)## when ##\dot a(t)=0## ?
And Inital conditons are like this casue of the acceleration equation ?
Arman777 said:
Is this true ?
Sure.
Some maximum value that you can calculate from the condition of H=0. But keep in mind that this scale is arbitrary. Multiplying the scale factor by 2 everywhere doesn't change the universe.
We don't know if the initial conditions have some deeper reason, but using them we can calculate the evolution of the universe.
mfb said:
Sure.Some maximum value that you can calculate from the condition of H=0. But keep in mind that this scale is arbitrary. Multiplying the scale factor by 2 everywhere doesn't change the universe.We don't know if the initial conditions have some deeper reason, but using them we can calculate the evolution of the universe.
You are right yes, scale factor itself don't mean anything..
Thats nice then.
So I want to ask just in case.
For ##k=0##
##\ddot a(t)=0## and ##\dot a(t)>0##
For ##k=-1##
##\ddot a(t)>0## and ##\dot a(t)>0##.
Related to Friedmann Equation - Positive Curvature
1. What is the Friedmann Equation?
The Friedmann Equation is a mathematical equation used in cosmology to model the expansion and evolution of the universe. It was developed by Alexander Friedmann in the 1920s and is a key component of the Friedmann-Lemaître-Robertson-Walker (FLRW) metric, which describes the geometry of the universe.
2. What does the Friedmann Equation predict for universes with positive curvature?
The Friedmann Equation predicts that universes with positive curvature, also known as closed universes, will eventually stop expanding and undergo a "Big Crunch" where all matter and energy in the universe collapses back into a singularity. This is in contrast to universes with flat or negative curvature, which will either continue expanding forever or experience a "Big Rip" where the expansion accelerates and tears matter apart, respectively.
3. How does positive curvature affect the expansion rate of the universe?
Positive curvature causes the expansion rate of the universe to slow down over time. This is because the positive curvature acts as a gravitational force, pulling matter and energy back towards the center of the universe. As a result, the rate of expansion decreases as time goes on.
4. Is there evidence for positive curvature in our universe?
There is currently no definitive evidence for positive curvature in our universe. However, some studies have found hints of positive curvature in the cosmic microwave background radiation, which is the leftover thermal radiation from the Big Bang. Further research and observations are needed to confirm or refute the presence of positive curvature in our universe.
5. How does the Friedmann Equation account for the effects of dark energy on positive curvature universes?
The Friedmann Equation includes a term for the density of dark energy, which is a hypothetical form of energy that is thought to be responsible for the observed acceleration of the universe's expansion. In positive curvature universes, the presence of dark energy would counteract the gravitational effects of the positive curvature, potentially leading to a longer period of expansion before the eventual collapse. However, the exact role of dark energy in positive curvature universes is still a topic of ongoing research and debate.
  • Cosmology
  • Cosmology
