Friedmann's Acceleration Equation
  • Thread starter johnnnyboy92
  • Tags
    Acceleration
In summary, according to the acceleration equation in general relativity, a positive pressure in the universe will result in a slower expansion due to the increased gravitational attraction from the higher energy density. This is different from Newtonian gravity, where mass is the only source of gravity. In general relativity, both mass and energy contribute to the gravitational field, and the higher the pressure, the higher the energy density, leading to a slower expansion. This can be seen in the ideal gas equation, where higher pressure means higher temperature and thermal energy. In cosmology, this relationship is described by the equation of state P=wε, where w is a constant.
johnnnyboy92
The acceleration equation is:
[itex]\frac{\ddot{a}}{a}[/itex] = -[itex]\frac{4πG}{3c^2}[/itex](ε+3P)
According to this equation, if we have a positive pressure, then the expansion of the universe will slow down. I'm confuse about this because I think of positive pressure resulting from the random thermal motions of particles pushing out in a container for example. The greater this pressure is, the greater the force the walls will feel outward. So how can the universe slow down if the pressure is positive?
Space news on Phys.org
According to general relativity, the pressure contributes to the overall gravitational field; more pressure means more gravitational attraction to slow the outwards acceleration.
Likes 1 person
Very roughly ...
In Newtonian gravity, mass is the source of gravity. Because of the equivalence of mass and energy, in general relativity, mass and energy are sources for gravity.
Consider the ideal gas equation ##PV=NkT## as an example. The higher the pressure, the higher the temperature and thus thermal energy.
Likes 1 person
ohhhh, I see now. Correct me if my interpretation of your answers is wrong, but for cosmology, the mathematical relation between pressure and energy density, where we deal with dilute gases, is the equation of state is P=wε. And, since we are dealing with general relativity, like you guys said, then the positive pressure means there's going to be more energy density. If there's more energy, then space-time is curved causing the expansion to slow down because there's more gravity according to Einstein.
I can understand your confusion regarding the relationship between positive pressure and the expansion of the universe. However, it is important to note that this equation is not describing the behavior of particles in a container, but rather the behavior of the entire universe.
The Friedmann's acceleration equation is a fundamental equation in cosmology that describes the evolution of the universe. The term "pressure" in this context refers to the pressure exerted by the matter and energy in the universe, which includes not only particles but also radiation and dark energy.
When the pressure is positive, it means that the matter and energy in the universe are pushing against each other, which can slow down the expansion of the universe. This is because the positive pressure contributes to the total energy density in the equation, which has a negative effect on the acceleration of the universe.
Furthermore, it is important to note that the expansion of the universe is not solely determined by pressure, but also by the overall energy density and curvature of the universe. So even though a positive pressure can slow down the expansion, it is not the only factor at play.
In summary, the Friedmann's acceleration equation is a complex equation that takes into account various factors in the universe, including pressure, to describe its evolution. While it may seem counterintuitive, a positive pressure can indeed contribute to the slowing down of the universe's expansion.
FAQ: Friedmann's Acceleration Equation
1. What is Friedmann's Acceleration Equation?
Friedmann's Acceleration Equation is a mathematical equation used in cosmology to describe the expansion rate of the universe. It was developed by Russian physicist Alexander Friedmann in 1922 and is one of the key equations in the study of the evolution of the universe.
2. How does Friedmann's Acceleration Equation relate to the expansion of the universe?
Friedmann's Acceleration Equation is used to calculate the expansion rate of the universe, also known as the Hubble parameter. It takes into account the density of matter and energy in the universe and describes how the expansion rate changes over time.
3. What are the key variables in Friedmann's Acceleration Equation?
The key variables in Friedmann's Acceleration Equation are the Hubble parameter (H), the density of matter (ρ), and the density of energy (Λ). These variables are used to calculate the expansion rate of the universe and are affected by the composition of the universe.
4. How does Friedmann's Acceleration Equation support the theory of the Big Bang?
Friedmann's Acceleration Equation is a fundamental equation in the Big Bang theory. It describes the expansion of the universe and how it has changed over time, which aligns with the predictions of the Big Bang model. Additionally, the equation can be used to support the concept of an expanding universe and the idea that it began from a singularity.
5. Are there any limitations to Friedmann's Acceleration Equation?
While Friedmann's Acceleration Equation is a useful tool in understanding the expansion of the universe, it has its limitations. It assumes a homogenous and isotropic universe, which may not be entirely accurate. Additionally, it does not take into account the effects of dark energy, which is a major component of the universe's energy density.
