From where comes Gravity energy?
In summary, the conversation discusses the concept of gravitational potential energy and the energy of an object falling in a gravitational field. It is explained that in both Newtonian theory and relativity, the energy of an object falling is constant. The question is raised about where the energy comes from and if there is any consumption involved. It is clarified that the energy comes from the object's position in the gravitational field and work is done as the object moves. This is consistent with previous posts in the conversation.
Neoφ
Hello,
first I'm glad having found this very interesting forum.
Initially I hesitated before asking my question, because its answer is probably obvious for the specialist. But my physics studies were a long time ago, and I must say the gravity related issues are being confused in my brain.
The question that came to mind after reading other interesting posts:
Due to curved space-time (as they say) an object will visually fall towards the center of a massive object nearby (typically my iPhone towards the wooden floor on Earth [not broken]).
From where comes the energy that moves the object? Is there some consumption somewhere? Is it just a matter of fact due to the Universe rules?
Meaning, if nothing would change on Earth/Universe, the same force would be applied to objects without reduction infinitely?
Thanks.
In both Newtonian theory and relativity, the energy of an object falling in a static gravitational field is constant. An object which is in a higher potential has "potential energy" due to that position. When it is freely falling (where that term includes orbits and being thrown upwards), the potential energy can be converted to or from kinetic energy, but the total is constant.
I do not understand your last sentence...but if you are also thinking about force, then work IS done as an object moves in a gravitational field.
Gravitational potential energy is taken as zero at infinite distance from the center of attraction and the difference in potential energy at two points is the work done in moving a body from one point to another.
This is consistent with post #2.
FAQ: From where comes Gravity energy?
What is gravity energy?
Gravity energy is the potential energy that an object possesses due to its position in a gravitational field. It is the energy that is required to move an object against the force of gravity.
Where does gravity energy come from?
Gravity energy comes from the mass and distance between two objects. The larger the mass and the closer the distance, the stronger the gravitational force between the objects and the higher the gravity energy.
How is gravity energy related to gravity?
Gravity energy is directly related to gravity. The force of gravity is what causes objects to have potential energy, and the amount of potential energy an object has is determined by its position in a gravitational field.
Can gravity energy be converted into other forms of energy?
Yes, gravity energy can be converted into other forms of energy. For example, when an object falls from a certain height, its potential energy is converted into kinetic energy, which is the energy of motion.
Is gravity energy a renewable or nonrenewable source?
Gravity energy is a nonrenewable source because it is dependent on the mass and distance between objects, which cannot be easily changed. However, it is constantly present and can be harnessed for various applications such as hydroelectric power generation.
