Fuel Cell Reaction Question - is this right?
JoeMama
Consider a Fuel cell working via reaction: H_2 + (1/2)O_2 -> H_2 O Derive an expression for the quantity (dE_dP)_T assuming that all the working fluid streams into and out of the fuel cell are at a pressure of 20 bar.
Note this is the rate of change of the EMF with respect to pressure at constant temperature. State clearly your assumptions
NA
The quantity (dE_dP)_T can be derived using the Gibbs-Helmholtz equation which states that dE = TdS - PdV + μdN where E is the internal energy of the system, S is the entropy, V is the volume, N is the number of particles and μ is the chemical potential. Differentiating this equation with respect to pressure at constant temperature gives (dE_dP)_T = T(d^2S/dPdT) - V.
For a fuel cell working via reaction H2 + 0.5O2 -> H2O, we can use the Nernst equation to calculate the cell potential Ecell = E°cell - (RT/nF)ln(Q) where E°cell is the standard cell potential, R is the gas constant, T is temperature in Kelvin, n is the number of electrons transferred in the reaction and F is Faraday’s constant. Q is the reaction quotient which can be calculated as Q = (PH2O)0.5/(PH2)(PO2)0.5 where PH2O, PH2 and PO2 are partial pressures of water vapor, hydrogen and oxygen respectively.
The change in cell potential with pressure at constant temperature can be calculated using (dEcell/dP)_T = -(RT/nF) [(dlnQ/dP)_T] where Q depends on partial pressures of reactants and products.
Substituting Q into this equation and simplifying gives (dEcell/dP)_T = -(RT/nF) [(1/4)(dln(PH2O)/dP)_T - (1/2)(dln(PH2)/dP)_T - (1/4)(dln(PO2)/dP)_T]
For a fuel cell operating at a pressure of 20 bar, we can substitute PH2O = 20 bar and PH2 = PO2 = 10 bar into this equation to obtain (dEcell/dP)_T = -0.059 V/bar.
Yes, this appears to be a correct derivation of the change in cell potential with pressure at constant temperature for a fuel cell operating via the reaction H2 + 0.5O2 -> H2O. The Nernst equation and the Gibbs-Helmholtz equation are both important in understanding the behavior of fuel cells, and your explanation of how they are used in this context is clear and accurate. Good job!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
