- 1,143
I read about incidences of fuel tank explosions in commercial airliners recently. (For example, this http://www.cnn.com/2006/US/07/14/twa.main/index.html" ). I'm aware of four incidences of fuel tank explosions on commercial airliners. All four were on Boeing airplanes.
- The first was in 1990 when a Boeing 737-300 operated by Philippine Airlines exploded on the ground while taxiing [1]
- Then in 1996, was the tragic incident when a Boeing 747-131 operated by Trans World Airlines exploded in midair some 12 mins after take off from JFK [2]
- The next one was in 2001, when a Boeing 737-400 of Thai Airways exploded, half an hour before scheduled take off. [3]
- And the last one I'm aware of happened in 2006, when the left wing fuel tank of a Boeing 727 of Transmile Air Service exploded in Bangalore while being towed on ground. [4]
The Nation Transportation Safety Board says that available evidence from these incidents suggests that the cause is the ignition of fuel-air mixture in the center wing fuel tank. Also, the Caltech Explosion Dynamics Laboratory performed a series of experiments which highlighted the flammability of fuel/air mixtures of jet fuel [5].
I have many comments and questions on this. It would be great if someone could help.
First of all, why only boeings? I read that a problem with the boeings is that the heat sinks of the air conditioning system are located beneath the center wing fuel tanks which could rise the temperature and flammability of the fuel mixture [5].
Does anyone know for which models, the location of the AC heat sinks is an issue? Does this affect the newer 777's? Did Boeing make any changes regarding this issue in the newer aircrafts after the TWA disaster?
Also, I read that there was going to be an inerting system introduced in some 747's which reduces the oxygen content using nitrogen. Why only the 747's?
Then, the FAA introduced some regulations to reduce the occurrences of ignition in the fuel tanks. Were these implemented globally, or only on US aircrafts?
Is there any reason that three of these four incidents occurred when the plane was on the ground (radiant heat from tarmac)? Or was it luck?
I also read that some airbus models (the 320 & 340) were also susceptible to center wing fuel tank explosions. What is airbus going to do on this?
Refs:
[1]-http://aviation-safety.net/database/record.php?id=19900511-1&lang=en"
[2]-http://aviation-safety.net/database/record.php?id=19960717-0&lang=en"
[3]-http://www.ntsb.gov/Events/twa800/"
[4]-http://www.ntsb.gov/Pressrel/2006/060712a.htm"
[5]-http://www.galcit.caltech.edu/EDL/projects/JetA/background.html"
* This sudden interest is due to my (now intense) dislike of flying. I'm aware that statistically, flying is the one of the safest form of travel per km of distance traveled. Yet, I've got a boeing 777 flight to catch soon, and I'm scared *
Refs:
