Full Pressure release valve
A mechanical pressure release valve is needed that opens at 10 to 15 bars and remains open until all pressure is released, ideally with an automatic reset feature. Suggestions include a spring-loaded pin to block closure, requiring manual reset, or a spring-loaded diaphragm for potential automatic reset, though this may not allow closure under partial pressure. The valve must withstand up to 225 psi before opening and stay open until flow ceases, which may not be met by existing products. An alternative design proposed involves a hanging flap valve activated by a magnet that opens with pressure and closes as flow decreases. The discussion highlights the challenge of finding a commercially available solution that meets these specific mechanical requirements.
deval vyas
TL;DR
Pressure release valve that operates to release all the pressure
A mechanical pressure release valve opens at pre designed pressure and then automatically closes once pressure drops to a lower point generally around 5 to 10% of the designed release pressure.
However I need a mechanical pressure release valve which opens automatically at pre designed pressure around 10 to 15 bars... but does not close until All the pressure is released.
The valve can could then reset automatically once all the pressure is released.
It has to be a mechanical valve and Electricity can't be used.
The valve has to ideally reset automatically. However if automatic reset is not possible then manual reset has to happen without replacement of any parts... So a rupture disk or breaking pin etc can't be used.
May be it has a stopper pin or something which will not allow the pressure release valve to close automatically.. Unless it's reset...
Is there any way to design such a valve?
deval vyas said:
Summary:: Pressure release valve that operates to release all the pressure
Yes.
A spring-loaded pin that blocks the valve from closing. Manual reset by pulling the pin and closing the valve.
A possible Auto- reset could be substituting a spring loaded diaphragm (sensing the tank pressure) pushing the pin in and a weak spring retracting the pin. Note that this would not allow the valve to close under partial tank pressure without manual intervention (as may be needed for testing purposes).
Cheers,
Tom
Likes Lnewqban and deval vyas
Tom.G said:
Yes.
Cheers,
Tom
Thanks Tom. Does it go by any particular name or Is it available in market with any company? I Can directly talk with them and source it.
The problem here is that the valve must withstand up to 225 psi before it cracks, to full open. It must then stay open until the flow stops. I don't think there is an available product that satisfies your requirement.
I would consider a hanging flap valve, held shut by a magnet. When pressure reaches the trigger pressure, the magnet let's go, the valve opens and the flap is held open by the flow. As the flow reduces the flap gradually sinks against the flow, until the magnet gets close enough to re-seal the valve.
Likes Tom.G and Lnewqban
Do pneumatic controls count as "mechanical"? What exactly/why is that constraint?
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 22 ·
