MikeDB
- 3
Hello,
I am trying to understand the details of the full treatment of synchrotron radiation. I am using Rybicki & Lightman (1979), along with the more detailed treatment given by Longair (1992).
For instance, in Longair, chapter 18 (p.240 in the Second Edition), I see that the radiated energy per unit solid angle per unit angular frequency is evaluated at the retarded time, and a change of variable is operated: going from time t to retarded time t',
with t' = t - R(t')/c.
and
R(t') = r - n.r_o(t')
(n is the unit vector along the direction joining the particle to the point where the radiation is measured, and r_o(t') is the position vector of the particle at t')
In the exponential factor exp(i w t) coming from the Fourier transform, the change of variable leads to
exp(i w ( t'+R(t')/c )).
It is then said that r_o(t') << r (I agree with that, as the source is at a quite large distance), and finally the exponential factor becomes
exp(i w ( t' - n.r_o(t')/c ))
I can't understand how to obtain this last result. Probably a first order expansion could be applied somehow but I don't see where and how.
Please, could someone give me an explanation for that?
Thank you so much in advance for your help.
Best regards.
and
Best regards.
