Fun Projectile Motion with football
In summary, the speaker's friend scored a great football goal that was posted on Youtube. The speaker, a mechanical engineering university student, wanted to test their physics skills by calculating the initial velocity of the ball using projectile motion equations. After making some assumptions and calculations, they estimated the initial velocity to be around 200 km/h, which is similar to the speed of some professional soccer players' shots. The speaker is open to others trying the calculations and has also shared the dimensions and assumptions used in their calculation.
faymalaka
Hey guys, my friend recently scored a great football goal and it was posted on youtube. I'm mechanical engineering uni student and i wanted to test my physics invoving projectile motion to calculate the Initial velocity of the ball.
After some calculations i came across a startling answer of around 200Km/h. This is pretty fast, but considering some of the fastest professorial soccer players shots have reaches speeds of around 200km/h, who are much older and better at football, i have some belief in my results.
For anyone interested in applying some simple projectile motion equations please let me know what you get.
*i also have attached my working*
The video:
Dimensions used: http://allsporttech.com/files/soccer-field-dimensions-diagram-lrg.gif
natural i would of had to make some assumptions:
1. Zero acceleration/deceleration in the x direction.
2. After contact with the foot the ball made a straight line (no curve) toward the top left corner.
3. The ball did not reach max height
.Using the given dimensions i measured the ball traveled a total distance of around 65m.Assuming a constant vertical acceleration of 9.8 m/s^2, and a horizontal initial velocity of 0, i found the initial velocity of the ball to be around 200 km/h. This is obviously not an exact answer as the above assumptions are incorrect, however, it does give a rough estimate of the velocity the ball was travelling at.
FAQ: Fun Projectile Motion with football
How does the shape of a football affect its projectile motion?
The shape of a football, with its pointed ends, can cause it to experience a change in air resistance as it moves through the air. This can alter its trajectory and create a curved or non-linear path.
What factors influence the distance a football can travel when thrown?
The distance a football can travel when thrown is influenced by factors such as the initial velocity of the throw, the angle at which it is thrown, the air resistance it experiences, and the force of gravity.
How does the force of gravity affect the trajectory of a football?
The force of gravity acts on a football throughout its entire flight, pulling it towards the ground. This force causes the football to follow a parabolic path, resulting in a curved trajectory.
Can a football be affected by wind during its projectile motion?
Yes, wind can have a significant impact on the trajectory of a football. Depending on the direction and strength of the wind, it can either assist or hinder the flight of the football, altering its final position.
How does air resistance affect the flight of a football?
Air resistance, also known as drag, can slow down the speed of a football as it moves through the air. This can lead to a shorter distance traveled and a steeper descent. The shape and surface texture of the football can also impact the amount of air resistance it experiences.
