Function in W plane gets mapped to the Z plane as?
In summary, the homework statement is that a function is given as W = ln (Z) where Z = x + i y and W = u + i v. The u = constant lines get mapped in z plane as ?. The attempt at a solution is that function w is w = ln (sqrt {[x2 + y2 ] } multiply with ei (theta). Now ln (a b) = ln (a) + ln (b) so w = ln (sqrt [x2 + y2 ]) + i(theta) ln (e). The first part is real, while second part is imaginary. w = u + iv.
jaus tail
615
48
A function is given as W = ln (Z)
Z = x + i y
W = u + i v
i is sqrt of (-1)
Z = x + i y = [ sqrt {x2 + y2 } ] ei (theta)
where theta is tan-1 (y/x)
Function w is
w = ln (z)
= ln( sqrt {[x2 + y2 ] } multiply with ei (theta)
w = u + iv.
So u = ln(sqrt [x2 + y2 ] )
Question says u = constant lines get mapped in z plane as ?
u = constant
so ln (sqrt (x2 + y2 ) = constant.
Now how to proceed? In answer they've said concentric circles with radius ec.
I got till u = ln (sqrt (x2 + y2)
remove sqrt out as 1/2 we get:
u = 1/2 ( ln (x2 + y2) )
equation of circle is x2 + y2 = constant.
But there is log in u.
Do you not recognize [itex]\ln\sqrt{x^2 + y^2} =\ln |z| = c[/itex] as [itex]|z| = e^c[/itex], which is a circle of radius [itex]e^c[/itex]?
Likes jaus tail
But question asks for mapping of lines u = constant.
And not mapping of lines eu = constant.
I understand how you removed log part by using exponential, but we need u = constant,
and not eu = e constant
Like left hand side is u and not eu.
Ok now i get it. Mapping on z plane, means we need 'x' in terms of 'y'
Equation that we get is: ln sqrt (x2 + y2 ) = constant c
to get x in terms of y,
sqrt (x2 + y2 ) = ec
so squaring we get
x2 + y2 = ec(2) --- equation of circle. radius ec
that is x2 = e2c - y2
Thanks.
PS how do you put the sign of square root over x2 + y2
Related to Function in W plane gets mapped to the Z plane as?
What is the function in W plane?
The function in W plane is a mathematical function that maps a point in the complex plane to another point in the complex plane.
What is the Z plane?
The Z plane is another complex plane that the function in W plane maps the points to. It is a different representation of the complex plane, with the real numbers represented on the horizontal axis and the imaginary numbers represented on the vertical axis.
How does the function in W plane get mapped to the Z plane?
The function in W plane gets mapped to the Z plane through a process called complex mapping. This involves applying the function to each point in the W plane and plotting the resulting points on the Z plane.
What does the function in W plane represent?
The function in W plane represents a transformation or deformation of the original complex plane. It can be used to study the behavior of complex functions and their properties.
What is the significance of mapping the function in W plane to the Z plane?
Mapping the function in W plane to the Z plane allows for a better understanding of the properties and behavior of complex functions. It also helps in visualizing and analyzing complex functions, making it a useful tool in many fields such as physics, engineering, and mathematics.
