Function Mapping to Open Intervals
In summary, the first question asks for a 1-1 function that maps (0,1) into S. The function is easy to find and is into S but not all members of S are mapped. The next question asks for a 1-1 function that maps S into (0,1). This is also easy to find and the function is onto S. The last question asks for a 1-1 function that maps S into N. This is not easy to find and the function is not onto S.
linuxux
133
Hello, I'm working on some questions and I need some further explanation;
First I must Consider the open interval (0,1), and let S be the set of point in the open unit square; that's is, S={(x,y):0<x,y<1}.
Question (a) says Find a 1-1 function that maps (0,1) into, but not necessarily onto, S. (this is easy)
So my first thought is the function [tex](\frac{1}{a},\frac{1}{b}) : a,b\in\mathbf{N}[/tex]. I think this function is into, but not all the members of the set S are mapped to, thus not being onto. Is this right?
The next question i had a problem with: (b) Use the fact that every real number has a decimal expansion to produce a 1-1 function that maps S into (0,1). Discuss whether the formulated function is onto. (keep in mind that any terminating decimal expansion such as .235 represents the same real number .2349999... .)
Heres my thought for (b), i define a set [tex]A_n , n\in\mathbf{N}[/tex] where n represents the number of decimal places. So n=1 would be one decimal place, n=2 would be two decimal places, and so on. With only one decimal place, [tex]A_1[/tex] contains every combination of (x,y) such that 0<x,y<1 for instance (.9,.3) or (.1,.5). [tex]A_2[/tex] contains every combination of (x,y) such that 0<x,y<1 to two decimal places, and so on.
So if i arrange all the [tex]A_n[/tex] like this:
[tex]A_1(1)[/tex] [tex]A_1(2)[/tex] [tex]A_1(3)[/tex] [tex]A_1(4)[/tex] ...
[tex]A_2(1)[/tex] [tex]A_2(2)[/tex] [tex]A_2(3)[/tex] ...
[tex]A_3(1)[/tex] [tex]A_3(2)[/tex] ...
[tex]A_4(1)[/tex] ...
and i arrange [tex]\mathbf{N}[/tex] like this:
1 3 6 10 ...
2 5 9 ...
4 8 ...
7 ...
Then S maps into [tex]\mathbf{N}[/tex] since i represented every decimal expansion in the array. Is this right? But I'm not sure how the reminating decimal affects this, since, for instance, .9 which belongs to [tex]A_1[/tex] is also .8999... .
The puzzling thing about this question is that at the end of the question it says this: The Schroder-Bernstein Theorem discussed in 1.4.13 to follow can now be applied to conclude that (0,1)~S.
Why would i apply something that follows to this question?
I don't understand how
is a function, let alone how it maps (0,1) into anything.
For your second question, why exactly are you trying to map S into N? They're asking you to map S into (0,1).
Finally, the Shroeder-Berstein theorem tells you that if you have two sets X and Y, a 1-1 function that maps X into Y, and a 1-1 function that maps Y into X, then there exists a bijection (i.e. a function that is both 1-1 and onto) from X onto Y. So, because this question asks you to find a 1-1 function from (0,1) into S, and a 1-1 function from S into (0,1), then you can apply the theorem and say that they (0,1)~S, assuming this notation means there's a bijection between them.
For the first part, I have to find a function that's maps (0,1) into the set S. I thought that a function was just a rule for selecting object, the objects we want to select in this case are x,y such that 0<x,y<1. so if i can find a way of selecting different values for x,y so that 0<x,y<1 then i can use that method as the function to map the open interval values to the set S. so if i select x,y values by using choosing any natural numbers a,b, and plug them into (1/a,1/b), then I'll get values that satisfy the requirement for values belonging to S which is 0<x,y<1. so 1/a,1/b acts as the into function. that's my reasoning, still wrong?
the second part is just wrong so i have to work on that...
I still don't see what your function is. For example, what is [itex]1/\pi[/itex] mapped to?
but the question says a function that maps into not necessarily onto, doesn't that's mean that not all S must be mapped? or i could just as easily pick any real numbers a,b > 0 which would cover pi, but since it said not necessarily onto i thought might as well just pick a and b from the natural numbers. if i was to specify that a and b are real numbers > 0, would the function still be incorrect?
That's my problem: What is your function?!
Let's call it f. What is f(1/2)? 1/2 is certainly in (0,1).
well, that's where it gets a little tricky... i have an example in my book where it defines what would be in the first few [tex]A_n[/tex]'s, for example it says [tex]A_1 = {\frac{0}{1}[/tex],[tex]A_2 = {\frac{1}{1},\frac{-1}{1}[/tex], [tex]A_3 = {\frac{1}{2},\frac{-1}{2},\frac{2}{1},\frac{1}{2}[/tex], and so on, the key is that the denominator and the numeration add to n in A_n. It then goes on to map N to the members of the various A_n sets. It then says this: 'Admittedly, writing an explicit formula for this correspondence would be an awkward task, and attempting to do so is not the best use of time.' So i thought this may be a similar case, but it looks like this approach was incorrect...
so how do i approach this problem?
As stated in the problem, this is actually a very easy and almost trivial problem. I guess the best hint to give is to think about what set you are trying to map into what other set, I mean in this case you want to try to map (0,1) into (0,1)X(0,1) (or S), you want a map that is one-to-one, but not necessarily onto.
First can you think of a map from (0,1) to (0,1) itself? Next can you somehow use this to find a map from (0,1) to S?
well, for any set A a function map to itself would be f(a)=a where a belongs to A. So are you saying the function I'm looking for is f(a,b)=(a,b) where a,b belong to R?
You seem to be missing what the question is asking.
You want to construct a function from (0,1) to S, i.e. your function f takes in values x in (0,1), and spits out values f(x) in S. So when you write f(a,b)=(a,b) where a,b belong to R, then you're definitely not answering the question at all. What you're doing is writing down a function from R2 to R2. Your function should look like f(x) = (y1, y2), where x is in (0,1), i.e. 0<x<1, and (y1, y2) is in S, i.e. 0<y1<1 and 0<y2<1.
An example of such a function is f(x) = (x/2, x^2). Here, for example, f(1/2)=(1/4, 1/4). Another example is f(x) = (1/3, x/7) (and f(1/2) = (1/3, 2/7) in this case).
Do you understand what you have to do now?
i think i understand, thanks.
Related to Function Mapping to Open Intervals
What is Function Mapping to Open Intervals?
Function Mapping to Open Intervals is a mathematical technique used to represent and analyze the relationships between two sets of data. It involves assigning each element in one set to a corresponding element in another set, often using a specific rule or formula.
How is Function Mapping to Open Intervals different from other types of function mapping?
Unlike other types of function mapping, Function Mapping to Open Intervals specifically focuses on mapping elements to open intervals, which do not include their endpoints. This allows for more accurate representation of the data and can provide deeper insights into the relationship between the two sets.
What are the benefits of using Function Mapping to Open Intervals?
Function Mapping to Open Intervals can help scientists and mathematicians better understand the patterns and relationships between two sets of data. It can also be used to make predictions and draw conclusions about the data, which can be applied to real-world scenarios and problems.
How is Function Mapping to Open Intervals used in scientific research?
Function Mapping to Open Intervals is commonly used in scientific research to analyze and model various phenomena, such as population growth, chemical reactions, and weather patterns. It can also be used in fields such as economics and engineering to study and predict trends and behaviors.
Are there any limitations or drawbacks to using Function Mapping to Open Intervals?
Like any mathematical technique, Function Mapping to Open Intervals has its limitations. It may not be suitable for all types of data and relationships, and it relies on accurate and precise data input. Additionally, it may not be able to account for all factors that could affect the relationship between the two sets of data.
