Function on both sides of an inequality?
In summary, you can apply monotone functions on both sides of an inequality, as long as they preserve the inequality. This means that for a monotone increasing function, x>y if and only if f(x) > f(y). For a monotone decreasing function, x>y if and only if f(x) < f(y). However, for general functions, you need to identify regions where the function is monotone increasing or monotone decreasing. Additionally, when dealing with more complex inequalities, it is important to consider boundaries where the function is discontinuous or undefined in order to determine if the inequality holds true throughout a given region.
phymatter
131
Can we apply any function on both sides of an inequality irrespective of its nature and without checking any conditions?
Mathematics news on Phys.org
No...not even close.
Note 3 > -4 but (3)^2 < (-4)^2.
You can apply monotone functions which are by definitions which preserve the inequality. A monotone (increasing) function f has the property x>y iff f(x) > f(y). You can also apply a monotone decreasing function which will reverse the inequality.
Examples of monotone increasing functions are adding a constant, multiplying by a positive number, logarithms (where defined), exponentials with base > 1.
Monotone decreasing: reciprocal, negative multiples, exponentials with base < 1.
For general functions you need to identify regions where it is monotone increasing or monotone decreasing.
Careful. Reciprocal is only monotone decreasing if you restrict the domain to postive numbers only.
Oops, right it monotone decreasing except discontinuous at 0.
phymatter,
If you have a more complicated inequality you should bring all terms to one side so it is of the form f(x) >0 or f(x)<0 or one of the "or equal" cases.
You then find the solution to the equation f(x)=0 and these points are boundaries on regions of the real number line where the inequality can change from being true to false. But you must also consider points where f(x) is discontinuous or undefined. Once you determine all boundary points you can test the inequality between them and it will be either uniformly true or uniformly false throughout those regions.
Think of it as figuring where the graph of the function is above and where it is below the x axis.
What about raising both sides to a power, or taking a root of each side?
Are those monotone functions?
I'm not sure. I think they are sometimes, but not always.
FAQ: Function on both sides of an inequality?
1. What is the definition of a function on both sides of an inequality?
A function on both sides of an inequality is an equation where both sides of the inequality contain a function.
2. How do you solve a function on both sides of an inequality?
To solve a function on both sides of an inequality, you must first isolate the variable by using inverse operations. Then, solve for the variable to find the solution set.
3. Can a function on both sides of an inequality have multiple solutions?
Yes, a function on both sides of an inequality can have multiple solutions. This is because the solution set is a range of values that satisfy the inequality, rather than just one specific value.
4. What types of functions can be used on both sides of an inequality?
Any type of function can be used on both sides of an inequality. This includes linear, quadratic, exponential, and trigonometric functions.
5. Why is it important to check your solution when solving a function on both sides of an inequality?
It is important to check your solution when solving a function on both sides of an inequality because it is possible to get extraneous solutions. This means that the solution may satisfy the inequality but not the original equation. Checking the solution helps to avoid any errors and ensure that the solution is valid.
