Functional Equation: Find f(2012)
  • MHB
  • Thread starter juantheron
  • Tags
    Functional
And, $f(2012) = 2012$ or $-2012$.In summary, if $f$ is a Real valued function on the set of real numbers such that for any real $a$ and $b$, $f(af(b)) = ab$, then $f(2012)$ can only be either $2012$ or $-2012$. This is because the inverse of $f$ is itself, and there are only two possible solutions for $f(x)$: $x$ or $-x$.
juantheron
247
If $f$ is a Real valued function on the set of real no. such that for any real $a$ and $b$ and $f(af(b)) = ab$. Then $f(2012) = $
Hi jacks,
\(\mbox{By substituting, }a=1\mbox{ we get, }f[f(b)]=b\mbox{ for each }b\in\Re\,.\mbox{ Therefore the inverse of }f\mbox{ is itself.}\)
\(\mbox{Suppose there exist a real number }n\mbox{ such that, }f(n)=1\,.\mbox{ Then, }\)
\[f\left[mf\left(\frac{1}{m}\right)\right]=1=f(n)\mbox{ where }m\in\Re\mbox{ and }m\neq 0\]
\[\Rightarrow mf\left(\frac{1}{m}\right)=n\]
\[\Rightarrow f\left(\frac{1}{m}\right)=\frac{n}{m}~~~~~~~(1)\]
\[\Rightarrow f\left(\frac{1}{m}\right)=f\left[nf\left(\frac{1}{m}\right)\right]\]
\[\Rightarrow \frac{1}{m}=nf\left(\frac{1}{m}\right)\]
\[\Rightarrow f\left(\frac{1}{m}\right)=\frac{1}{mn}~~~~~~~~(2)\]
By (1) and (2);
\[n=\pm 1\]
Therefore \(n\) can be \(1\mbox{ or }-1\) depending on the function \(f\). Hence,
If the function \(f\) is defined such that, \(f(1)=1,\)
\[f(2012)=f(2012f(1))=2012\]
If the function \(f\) is defined such that, \(f(-1)=1,\)
\[f(2012)=f(2012f(-1))=-2012\]
Here's mine (same conclusion).
First I'll show that $f(1) \ne 0$
Sub $a = 0$ into the functional equation giving $f(0) = 0$
Then sub $a = b= 1$ giving $f(f(1)) =1$. If $f(1) = 0$ then$ f(0) = 1$ but $f(0) = 0$ contradiction.
Now set $b = 1$ so $f(a f(1)) = a$. If we let $f(1) = k$ then we have $f(ka) = a$ or $f(x) = \dfrac{x}{k}$
Returning back to the original function equation gives
$f(af(b)) = f\left(\dfrac{ab}{k}\right) = \dfrac{ab}{k^2} = ab$ giving $k = \pm 1$
Thus, $f(x) = \pm x$
FAQ: Functional Equation: Find f(2012)
How do you solve for f(2012) in a functional equation?
To solve for f(2012) in a functional equation, you need to plug in the given value of x, which in this case is 2012, into the equation and then solve for f(2012) using algebraic techniques.
What is the purpose of finding f(2012) in a functional equation?
Finding f(2012) in a functional equation allows us to determine the output value of the function at a specific input value, which in this case is 2012. This can be useful in understanding the behavior of the function and making predictions.
Can there be more than one solution for f(2012) in a functional equation?
Yes, there can be multiple solutions for f(2012) in a functional equation. This depends on the given equation and the values of the variables involved.
Is it possible to find f(2012) without knowing the entire function?
No, it is not possible to find f(2012) without knowing the entire function. The value of f(2012) is dependent on the function and its input values, so having incomplete information will not allow us to accurately find f(2012).
Are there any specific techniques for solving for f(2012) in a functional equation?
There are various techniques for solving for f(2012) in a functional equation, such as substitution, elimination, and graphing. The most appropriate technique will depend on the given equation and the individual's problem-solving skills.
