Functions in Normed Linear Space
In summary, the conversation discusses the calculation of the supremum norm for functions f and g in the complex function space defined as \{f,g \in \mathbb{C} [a,b]: p\ge || f(x)-g(x)|| \le q \forall x \in [a,b]\}. The speakers also mention the use of calculus methods to find the maximum value of |f(x)-g(x)|, the definition of the norm as the maximum of the absolute value of the function, and the need for specific values of a and b to draw the region where p≤|f(x)-g(x)|≤q for given functions f and g.
  • #36
That's not a norm. |f(t)-g(t)| is the absolute value of the real number f(t)-g(t).
  • #37
If that is the absolute value, it could be less than or equal to 6 fair enough, ie the RHS but how could it be '=' to '-'6, ie on the LHS since the modulus is always positive?
Sorry, ignore this post. Thanks
  • #38
|a| <= 6 is equivalent to -6 <= a <= 6.
  • #39
Fredrik said:
Plot the graphs of the functions
\begin{align}
& x\mapsto x^3+9\\
& x\mapsto x^3+6\\
& x\mapsto x^3\\
& x\mapsto x^3-3
\end{align} and label them 1,2,3,4 respectively. Every g in D is contained in the region between graphs 1 and 4, and goes outside of the region between graphs 2 and 3 at least once.
Ok, thanks
How would you verify whether another new function like z(x)=5x is an element in A?
According to Wolfram, it looks like this function is with the region...
http://www.wolframalpha.com/input/?i=plot+x%5E3%2C+x%5E3%2B6%2C+x%5E3%2B9%2C+x%5E3-3%2C+5x+between+0+and+1
  • #40
[tex]\|f-z\|=\sup_{t\in[0,1]}|f(t)-z(t)|=\sup_{t\in[0,1]}|t^3+3-5t|=3[/tex] The last step is easy since the derivative of f-z doesn't have any zeroes in [0,1]. This means that f-z is either increasing in the entire interval, or decreasing in the entire interval. Since (f-z)(0)=3 and (f-z)(1)=-1, it must be decreasing, and the maximum value is 3.
  • #41
This is becoming interesting...so the slope if you like is negative ie (0,3) and (1,-1)...but what is the importance of determining its slope?
Is knowing what the resulting max value not enough, to determine whether f-z is in A?
Thanks Fredrik :-)
  • #42
What you need to determine is the max value in the interval. Since the slope is never zero inside the interval, we know that the function has its max value at one of the endpoints of the interval.
If the slope had been zero somewhere in the interval, then that might have been the point where the function has its max value.
  • #43
There seem to be some gaps in you knowledge...
If a differentiable function f is increasing on an interval [a, b], its smallest value is f(a) and its largest is f(b). OTOH, if f is decreasing on [a, b], its largest value is f(a) and its smallest is f(b). These are very simple ideas.
Thanks Fredrik :-)
  • #44
So if I had different function like f-z = t^3-t^2 say, then the derivative of this wrt t and subbing in 0 we would get 0 which would impy the max is at t=0?
I am just looking for an example that demonstrates the slope being 0 somewhere in the interval instead of at the ends...
Just one little query regarding the [itex]\|f-z\|=\sup_{t\in[0,1]}|f(t)-z(t)|=\sup_{t\in[0,1]}|t^3+3-5t|=3[/itex]
You put in 0 and you are left with 3. If you put in 1 we get -1. So we take the highest of those two because [itex]sup_{t \in [0,1]} | f-z|=max\{t_1,t_2\}[/itex] or something like this?
  • #45
I'm not a fan of the notation f-z=t^3-t^2, because it looks like a function equal to a number. If f-z satisfies [itex](f-z)(t)=t^3-t^2[/itex] for all [itex]t\in[0,1][/itex], then [itex](f-z)'(t)=3t^2-2t[/itex] for all [itex]t\in [0,1][/itex], so [itex](f-z)'(t)=0[/itex] implies [itex]t=2/3[/itex].
Yes, that's right.
  • #46
but how would we determine whether this new function is in A? Ok, you have identified that the maximum value lies somewhere at a point corresponding to t=2/3 because this is where the slope is 0. How do we establish whether the function lies above x^3+9 say?
  • #47
I think you called the set D earlier. What we have to do is of course to determine [itex]\|f-g\|[/itex], and this is fairly straightforward. I'll leave that to you.
I'm not sure why you would want to know, but in general, if you have two functions F and G, and want to know if one of them is "above" the other, you need to find out if the equation F(x)=G(x) has any solutions. If it doesn't, the graphs never intersect.
  • #48
bugatti79 said:
Ok, thanks
How would you verify whether another new function like z(x)=5x is an element in D?
Just a question on these 2 post. Do we conclude that the function z(x)=5x is in D because the maximum value of 3 is less than our highest intercept of 9 and greater than -3?
  • #49
A function [itex]g\in C[0,1][/itex] (where [itex]C[0,1][/itex] now denotes real-valued continuous functions on [0,1]) is in D if and only if [itex]3\leq\|f-g\|\leq 6[/itex]. So to check if z is in D, you have to find [itex]\|f-z\|[/itex], and I did. [itex]\|f-z\|=3[/itex]. Since [itex]3\leq 3\leq 6[/itex], z is in D.
  • #50
Brilliant, thanks Frekrik. As you can see my ability isn't good but at least I can keep learning. :-)
  • #51
So we can verify this by checking that the derivative of f-z is not 0. If is WAS 0, then there would be a possibility that the max value could be higher than 6 hence not in D...?
  • #52
I have been reading this thread since my first post which was #2. I am curious bugatti79 about two questions:
1. What course are you currently studying where this topic arose?
2. Have you taken a course in calculus?
  • #53
f-z has a local maximum at t if and only if (f-z)'(t)=0 and (f-z)''(t)<0. So if (f-z)'(t)≠0 for all t, then we can be sure that f-z doesn't have any local maxima in the interval.
It looks like you need to refresh your memory about some basic calculus (as a couple of people have already suggested).
  • #54
1) I am attempting to study analysis as a module which I find difficult as you can see. I will give it a go and see what happens.
2) No I have not taken a course in calculus but I come from an engineering background so I have some exposure to basic calculus which I guess I need to brush up on!
I am finish with thread now :redface:
Thanks
