Functions in reals such that inequality holds
In summary: Therefore, the only functions satisfying the given inequality are constant functions. In summary, the given inequality implies that the function f must be differentiable and its derivative must be equal to 0 for all values in its domain. This means that the only functions satisfying the inequality are constant functions.
maximus101
for which f: [tex]R[/tex] [tex]\rightarrow[/tex] [tex]R[/tex] such that
[tex]\forall[/tex] [tex]x,y[/tex][tex]\in[/tex] [tex]R[/tex]
does
| [tex]f(y)[/tex] - [tex]f(x)[/tex] | [tex]\mid[/tex] [tex]\leq[/tex] [tex](y-x)^2[/tex]
hold
Which inequality?
sorry just fixed it
so I did the following:
[tex]\dfrac{|f(y) - f(x)|}{|y-x|}\leqslant |y-x|[/tex]
was obtained by [tex](y-x)^2[/tex]=[tex]|y-x||y-x|[/tex] and dividing both sides by [tex]|y-x|[/tex].
then trying to use the fact that
[tex]\displaystyle\lim_{y\to x}\frac{f(y)-f(x)}{y-x}[/tex] is the derivative at x
but not sure what's next how to combine the two?
Is the function differentiable? If it isn't you can't use the limit thing. But if it is, apply the limit to both sides. You should then get something very familiar and be able to deduce what kind of function f must be.
Okay, if f isn't differentiable, here's a hint. Divide the interval from [x,y] into n equal sub intervals. See if you can get anything from that.
Wouldn't this statement
automatically imply the function is differentiable?
Yes. Using the squeeze theorem you can see that the derivative is actually 0 everywhere, implying the only functions satisfying the inequality are constant functions.
Am I missing something? I don't see any derivatives anywhere, just the difference quotient.
If you indented for it to be the difference quotient, then a counter example would be [tex]r \mapsto r^3[/tex]. For all |x-y| >= 1, [tex]\left| x^3 - y^3 \right| > \left( x - y \right)^2[/tex]
Assume there exists a function f satisfying [tex] 0 \le |f(y) - f(x)| \le (y-x)^2 = |y-x|^2 [/tex] for any y, x in the domain of f. This implies that [tex] 0 \ le \frac{|f(y) - f(x)|}{|y-x|} \le |y-x| [/tex].
Let y approach x. By the squeeze theorem, we see that the limit exists, is equal to 0, and is in fact the derivative of f evaluated at x. So f'(x) = 0 for all x in its domain, which means that f must be a constant function.
FAQ: Functions in reals such that inequality holds
What is the definition of a function in reals such that inequality holds?
A function in reals such that inequality holds is a mathematical concept where the output of a function is always greater than or equal to the input. This means that for any two real numbers x and y, if x is less than y, then the output of the function at x is less than or equal to the output of the function at y.
How do you represent a function in reals such that inequality holds?
A function in reals such that inequality holds can be represented using an inequality symbol, such as ≤ (less than or equal to) or ≥ (greater than or equal to). For example, f(x) ≤ g(x) represents a function where the output of f(x) is less than or equal to the output of g(x).
What is the importance of functions in reals such that inequality holds in mathematics?
Functions in reals such that inequality holds are important in mathematics because they help us understand and model real-world situations where inequalities are present. They are also essential in solving and graphing systems of inequalities and in optimization problems.
Can a function in reals such that inequality holds have multiple inputs for the same output?
Yes, a function in reals such that inequality holds can have multiple inputs for the same output. This means that there can be more than one value of x that produces the same output value y. These types of functions are called one-to-many functions.
How can you determine if a function in reals such that inequality holds is increasing or decreasing?
A function in reals such that inequality holds is increasing if its output values increase as the input values increase. In other words, as x increases, f(x) also increases. Conversely, a function is decreasing if its output values decrease as the input values increase. In other words, as x increases, f(x) decreases.
