Functions not satisfying parallelogram identity with supremum norm
In summary, the conversation discusses the task of finding two continuous functions on [0,1] that do not satisfy the given equation involving the supremum or infinity norm. The parallelogram identity is mentioned as a helpful equation. The attempt at a solution is to try different functions, and eventually two functions that satisfy the criteria are suggested: f(x) = x and g(x) = x-1.
JackTheLad
Find two functions [tex]f, g \in C[0,1][/tex] (i.e. continuous functions on [0,1]) which do not satisfy
[tex]2 ||f||^2_{sup} + 2 ||g||^2_{sup} = ||f+g||^2_{sup} + ||f-g||^2_{sup}[/tex]
(where [tex]|| \cdot ||_{sup}[/tex] is the supremum or infinity norm)
Parallelogram identity: [tex]2||x||^2 + 2||y||^2 = ||x+y||^2 + ||x-y||^2[/tex] holds for any x,y
Honestly no idea.
Just try some functions. It's really not hard to find an example that doesn't work.
For posterity, two functions which fit nicely are
f(x) = x
g(x) = x-1
(I had tried lots of functions but they worked; not very helpful response)
FAQ: Functions not satisfying parallelogram identity with supremum norm
1. What is the parallelogram identity with supremum norm?
The parallelogram identity with supremum norm is a mathematical property that states that the norm of the sum of two vectors is equal to the sum of their individual norms squared. In other words, it is a way to measure the length or magnitude of a vector.
2. Why do some functions not satisfy the parallelogram identity with supremum norm?
The parallelogram identity with supremum norm only holds true for certain types of functions, specifically those that are continuous and have a finite limit at infinity. Functions that are not continuous or have an infinite limit at infinity will not satisfy this identity.
3. What is the significance of the parallelogram identity with supremum norm?
The parallelogram identity with supremum norm is important in functional analysis and the study of normed vector spaces. It allows us to measure the distance between vectors and determine whether a function is continuous or not. It also has applications in optimization and control theory.
4. Can a function satisfy the parallelogram identity with supremum norm for some values but not for others?
No, a function either satisfies the parallelogram identity with supremum norm for all values or it does not satisfy it at all. This property must hold true for all values in order for a function to meet the criteria.
5. How is the parallelogram identity with supremum norm used in real-world applications?
The parallelogram identity with supremum norm is used in various fields such as signal processing, image and video compression, and machine learning. It helps to quantify the error or distortion between an original signal or image and its approximation, allowing for more efficient and accurate data processing.
