Functions of Several Variables, Area?
In summary, the problem is on pg 922 in chapter 13.5 in the text, number 32. It reads: A triangle is measured and two adjacent sides are found to be 3 inches and 4 inches long, with an included angle of pi/4. The possible errors in measurement are 1/16 inch for the sides and .02 radian for the angle. Approximate the maximum possible error in the computation of the area.
CalleighMay
36
Hello, my name is Calleigh and i am new to the forum! I am in Calculus II and have a few questions on some problems. I am using the textbook Calculus 8th edition by Larson, Hostetler and Edwards. Could someone please help me?
The problem is on pg 922 in chapter 13.5 in the text, number 32. It reads:
I haven't had any problems like this in class, so i don't know what to do. My professor suggested drawing a picture, but i haven't the slightest clue even where to begin. My professor explained it to me but i didn't understand it at all... any help would be greatly appreciated.
Forget about finding the maximum possible error for now and simply find the area of the triangle. How would you go about doing that? Describe the process.
Thanks for the reply futurebird!
Well they give the triangle has one side 3 and one side 4, but doesn't give the opp side.
I thought maybe the angle between these two sides is 45 degrees (pi/4) but then how could i find the length of the other side? Wouldn't i just use 1/2b*h to find the area? To do that i need to be able to draw the triangle and find all angles and side lengths...
I found some equation i think may be helpful but i think my answer's wrong since my professor laughed at me when he saw it...
dA= 1/2((bsin(c) dA + asin(c) dA + abcos(c) dA)
dA= 1/2((4sin(pi/4) + 3sin(pi/4) + 3*4cos(pi/4)
dA= 1/2(2.83+2.12+8.49)
dA=1/2(13.44)
dA= 6.72
why is this wrong?
Oops i forgot part of the equation, i tried it again and got + or - .24 does that sounds about right? Thanks ;)
If I may offer a bit of advice, it seems you are more interested in getting the correct answer than in learning the proper technique to find that answer. This type of problem is an example of a very important practical application of calculus and learning the proper technique of solution is important. You said there was a part of your equation missing, but you have not showed us the equation (in full) that you are using now to get your result. You really need to show us what you are doing so that we may help you. To answer your last question, a deviation of .24 is much too high as it represents a deviation in area of 24%. That is a huge amount and is not justified by the small errors in the measurement of the sides or the angle. This problem can be easily solved by using a bit of analysis and reasoning. I’ll give you an example (which is not the solution to this particular problem): Suppose the measurement of one side is in error by 3%, the second side by 2% and the Sine of the measured angle by 1%. You can get a very good approximation of the possible error in the computation of area by just adding these together for a possible error of 6% in area. This will give you a good estimate of what your calculus-based solution should be. To do this, you need to calculate what percentage 1/16 of an inch is to a side of 3 inches and to a side of 4 inches as well as by what percentage the sine of .02 radians is to the sine of pi/4 radians then simply add those together to get the possible total variation in area. I can assure you it is considerably less than 24%! Once you get the idea of solving the problem this way, the calculus method of solving it using partial derivatives of the area function will make a lot more sense to you. Give it another try and see what you get, but please post your work as well as your result so that we may help you learn. Cheers!
dA= 1/2((bsin(c) dA + asin(c) dB + abcos(c) dC)
dC=+/- .02
dA=dB=+/ -1/16
a=3
b=4
c=pi/4
dA= 1/2((4sin(pi/4)1/16 + 3sin(pi/4)1/16 + 3*4cos(pi/4).02)
=1/2(.3133)
=.156652 which when rounding is +/- .24
Is this not the correct way to do it?
Do NOT use small letters and capital letters interchangeably! In some formulas "A" and "a" might be used to mean different things. It is common in geometry to use small letters for lengths of sides of triangle and the corresponding capital letters for the angles opposite those sides. So your area formula is
A= (1/2)ab sin(C).
From that dA= (1/2)( b sin(C)da+ a sin(C)db+ ab cos(C)dC).
dC=+/- .02
dA=dB=+/ -1/16
a=3
b=4
c=pi/4
=1/2(.3133)
Hi! Well, you are using the correct formula, but not quite in the correct manner. Besides mixing metaphors, as HallsofIvy has mentioned, there are some other fundamental mistakes in your calculation method. What you are seeking to find is the total differential of the Area as a result of variations in several independent variables. This total differential will be expressed as a decimal ratio, or a percentage of the Area. So the variations in the independent variables must also be entered into the equation as decimal ratios, not in their individual units of measure. You cannot mix inches with radians and get a useful result, but you can mix the percentage of change in inches with the percentage of change in radians and get a percentage of change in Area. To that end, da = .0625/3 = .0208a, db = .0625/4 = .0156b and d Sin(C) = Sin .02/Sin (pi/4) = .028 Sin (C).
So now the formula becomes:
dA = (1/2)( b sin(C) .0208a + a sin(C) .0156b + ab .0208 sin(C) )
If you look closely at that equation you will see that it is now possible to factor out ab sin(C) from each term which leaves you with an elegant expression:
dA = (1/2) ab sin (C) (.0208 + .0156 + .0208)
dA = .0572 A so the Area can vary by 5.72% with the variations in the given parameters.
I hope this helps.
FAQ: Functions of Several Variables, Area?
What is the definition of a function of several variables?
A function of several variables is a mathematical relationship between multiple input variables and a single output variable. It maps a set of input values to a corresponding set of output values.
How do you graph a function of several variables?
To graph a function of several variables, you would need to plot points in a three-dimensional coordinate system. Each point would represent a set of input values and the corresponding output value. The graph would typically be a curved surface in three-dimensional space.
What is the difference between a function of one variable and a function of several variables?
A function of one variable has a single input variable and a single output variable, while a function of several variables has multiple input variables and a single output variable. This means that a function of several variables can take into account the relationship between multiple input variables, while a function of one variable cannot.
How do you calculate the area under a function of several variables?
The area under a function of several variables is known as a double integral. It is calculated by integrating the function over a region in the input space. The result is a single number that represents the total area under the function in that region.
What is the practical application of functions of several variables in science?
Functions of several variables are widely used in various fields of science, such as physics, engineering, and economics. They are used to model and analyze complex systems that involve multiple input variables, such as the relationship between temperature, pressure, and volume in thermodynamics, or the relationship between demand, supply, and price in economics.
