MHB Functions that are injective but not surjective
Math Amateur
MHB
I am reading Paolo Aluffi's book Algebra: CHapter 0.
In Chapter 1, Section 2: Fumctions between sets we find the following: (see page 13)
"if a function is injective but not surjective, then it will necessarily have more than one left-inverse ... "
Can anyone demonstrate why this is true?
Secondly, Aluffi goes on to say the following:
"Similarly, a surjective function in general will have many right inverses; they are often called sections."
Can someone please indicate to me why this also is the case?
Peter
This is easy. If $f:A\to B$ is injective but not surjective and $g\circ f=\text{id}_A$, then $g$ can map elements of $B\setminus\text{image}(f)$ anywhere.
If you know why a right inverse exists, this should be clear to you.
Here are some examples:
Consider the function:
$f: A \to B$ where $A = \{a_1,a_2\}$, and $B = \{b_1,b_2,b_3\}$ defined by:
$f(a_1) = b_1, f(a_2) = b_2$.
Define $g:B \to A$ by:
$g(b_1) = a_1, g(b_2) = a_2, g(b_3) = a_1$ and
$h: B\to A$ by:
$h(b_1) = a_1, h(b_2) = a_2,h(b_3) = a_2$.
It should be clear that:
$g \circ f = h \circ f = 1_A$, but $g \neq h$, so we have two distinct left-inverses for $f$.
Note that above, $g$ is surjective, and that $f$ is a right-inverse for $g$.
If we define: $k: A \to B$ by: $k(a_1) = b_3,k(a_2) = b_2$ it is clear $f \neq k$ but both $f,k$ are right-inverses for $g$.
In the older literature, injective is called "one-to-one" which is more descriptive (the word injective is mainly due to the influence of Bourbaki): if the co-domain is considerably larger than the domain, we'll typically have elements in the co-domain "left-over" (to which we do not map), and for a left-inverse we are free to map these anywhere we please (since they are never seen by the composition).
Surjective is also called "onto", it is often the case that a surjective function is "many-to-one", this often happens when the domain is considerably larger than the co-domain. Since we have multiple elements in some (perhaps even all) of the pre-images, there is more than one way to choose from them to define a right-inverse function.
Injective and surjective are not quite "opposites", since functions are DIRECTED, the domain and co-domain play asymmetrical roles (this is quite different than relations, which in a sense are more "balanced").
In set theory, a function $f:A \to B$ is defined so:
$f = S \subseteq A \times B: (a_1,b_1),(a_1,b_2) \in S \implies b_1 = b_2$ and $\forall a \in A, \exists b \in B: (a,b) \in S$.
this ensures that every element of $A$ is paired with just one element of $B$; for a given $a \in A$ this element is typically denoted $f(a)$ to indicate its dependence on $a$.
There is a natural association of the concept of function with "transformation"; this idea is already clear in ancient mathematical problems, where they might be stated so:
"Take a quantity, and divide it into equal parts, then add a third part of the whole: what is the result?"
which in modern terms might be illustrated so:
$x \to \dfrac{x}{2} \to \dfrac{x}{2} + \dfrac{x}{3}$
Functions, then, originally represented "things we did to numbers", and it was quite some time before it was recognized that functions could be defined to "act" on any kind of collection.
There is very little about functions that cannot be understood by examining functions where $A,B$ are finite, and have very few members. I urge you to look at a few.
Thanks Evgeny.
I appreciate your help ...
Peter
- - - Updated - - -
$h: B\to A$ by:
Thanks Deveno.
Just working through this post now and reflecting on what you have said.
Your examples are always extremely helpful in promoting understanding of principles and propositions.
Peter
But notice that this result depends on the domain of the function having more than one element. Suppose that $f:A\to B$ is a function whose domain $A$ consists of a single element $a$, and the codomain $B$ contains more than one element. Then $f$ is not surjective, but it has a unique left inverse $g$ defined by $g(b) = a$ for all $b$ in $B$.
Thanks for the helpful input Opalg,
Peter
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
