Functions - the fallacy in this argument
In summary: There are values in the codomain that are not mapped to by any element of the domain.In summary, the fallacy in this argument lies in the fourth line, where the author incorrectly evaluates f(sin x) as x sin x. This is not a valid function as it is not surjective, and therefore the proof is flawed.
autodidude
333
I'm asked to find the fallacy in this argument
sin ≣ sin(π - x)
Hence, f(sin x) = f(sin(π-x))
Let f(x) = x sin x
Then x sin x = (π - x)sin(π-x)
x = π - x
Hence π = 2x and since x is any value we choose, so is π
The fourth line, where the author says the x in front of the sin x is also equal to π - x is where the error is, but in the answers, he says, ''the fallacy is we cannot choose f(sin x) to be x sin x, this is not a function of sin x alone but of x and sin x'
I suspect he's talking about the same thing, but I don't understand what it has to do with the fourth line.
Mathematics news on Phys.org
From what I understand,
if you let
f(x) = xsinx
and u = sinx
then
f(u) = u*sin(u)
= sin(x)*sin(sin(x))
and likewise for sin(pi - x)
If you look at the proof, you see that the fourth line should be:
sin(x)*sin(sin(x)) = sin(pi - x)*sin(sin(pi - x))
which seems correct.
So it's basically two functions in one?
That's pretty meaningless in this problem.
The problem is that the 4th line does not evaluate f correctly. f maps a number into that number time the sin of that number.
For example,
f(x) = xsin(x)
f(y) = y sin(y)
f(a + b) = (a + b) sin(a + b)
f(sin(π-x)) = sin(π-x) sin(sin(π-x))
Are you sure you typed it out correctly? Because the answers only make sense if either the function was defined as [itex] f(\sin x) = x \sin x [/itex] or if the author is deciding to be bizarrely pedantic about the scope of the variable x, otherwise the problem is definitely in the 4th line.
JHamm is correct, the author either made a typo or the OP did.
For example,
f(x) = xsin(x)
f(y) = y sin(y)
Yeah, if I understand you correctly, that's what I thought. It's just his answer confused me.
@JHamm: Yeah, that's how the questioning and answer were given. I was wondering why he said we can't use f(sin x) to be x sin x because in the question he let f(x) = x sin x.
When I see f(sin x) = x sin x, I interpret that as sining the x before inputing it's sin(x)sin(sin(x)).
If you take [itex]f(x) = x\sin x [/tex] you can then go
[tex]f(\sin x) = \sin x \sin \sin x [/tex]
However if you try to define your function as
[tex]f(\sin x) = x\sin x [/tex]
Then you're in trouble because that isn't surjective.
FAQ: Functions - the fallacy in this argument
What is a function?
A function is a mathematical concept that represents a relationship between two variables, where each input has exactly one output. In simpler terms, a function is a rule that takes in an input and produces a corresponding output.
What is the fallacy in the argument about functions?
The fallacy in this argument usually refers to the common misconception that a function is simply a set of ordered pairs. While a function may be represented by a set of ordered pairs, it is not limited to just that. Functions can also be represented by equations, graphs, and verbal descriptions.
Can a function have more than one output?
No, a function can only have one output for each input. This is known as the vertical line test, where a vertical line can intersect a function's graph at most once. If a vertical line intersects the graph at more than one point, then the relationship is not a function.
How do you determine if a relationship is a function?
To determine if a relationship is a function, you can use the vertical line test or the horizontal line test. The vertical line test checks if each input has exactly one output, while the horizontal line test checks if each output has exactly one input. If either test fails, then the relationship is not a function.
Can all equations be considered functions?
No, not all equations can be considered functions. For an equation to be a function, it must pass the vertical line test. In other words, each input must have exactly one output. If an equation fails this test, then it is not a function.
