Fundamental Forces and Lie Groups
In summary: In other words, the particle can be in different "states" inside this internal space, and these states correspond to different types of charge. Just like in the case of U(1), these states can be transformed by elements of the Lie group associated to the Lie algebra, and these transformations are called gauge transformations.In summary, gauge symmetry is a fundamental concept in physics that describes the relationship between the forces in the universe and the symmetries of the underlying mathematical structure. For example, electromagnetism is described by the U(1) group, and its symmetry is related to the invariance of electric charge under rotations. Non-Abelian gauge theories extend this concept to include other forces, such as the strong
platypus0
Hi all,
Sorry, I'm not quite sure that I've posted this question in the proper place, but I figured field theory matches best with lie groups in this context.
Anyway, my question has to do with the relationship between the fundamental forces (electromagnetism, weak, and strong) and their lie groups -- U(1), SU(2), and SU(3), respectively. For example, what exactly does it mean to say that electromagnetism has U(1) gauge symmetry? I understand that it might have something to do with invariance with respect to rotations -- but then, how does something's electric charge correspond to U(1), which is simply the circle group of complex numbers [itex]\left|z\right|=1[/itex]?
Thanks.
It's a symmetry in an abstract space of fields (or field operators in the quantized case).
The local gauge symmetry of classical electrodynamics is easily seen by the fact that the physically observable fields are [itex]\vec{E}[/itex] und [itex]\vec{B}[/itex] fulfilling Maxwell's equations. These consist of two constraint equations (the homogeneous equations)
[tex]\vec{\nabla} \times \vec{E}+\partial_t \vec{B}=0, \quad \vec{\nabla} \cdot \vec{B}=0.[/tex]
These equations can be identically satisfied by introducing a scalar and a vector potential. Indeed since the magnetic field is solenoidal, it can be written as
[tex]\vec{B}=\vec{\nabla} \times \vec{A}.[/tex]
Now, plugging this in the first constraint, gives
[tex]\vec{\nabla} \times (\vec{E}+\partial_t \vec{A})=0,[/tex]
which means that the field in the brackets has a scalar potential:
[tex]\vec{E}+\partial_t \vec{A}=-\vec{\nabla} \Phi[/tex]
or
[tex]\vec{E}=-\partial_t \vec{A}-\vec{\nabla} \Phi.[/tex]
A given scalar and vector potential thus give electric and magnetic fields as
[tex]\vec{E}=-\partial_t \vec{A}-\vec{\nabla} \Phi, \quad \vec{B}=\vec{\nabla} \times \vec{A}.[/tex]
On the other hand, obviously, for given electric and magnetic fields, the potentials are not unique. One can add the gradient of a scalar potential to the vector potential without changing the second equation:
[tex]\vec{A}'=\vec{A}+\vec{\nabla} \chi[/tex]
leads to the same magnetic field as [itex]\vec{A}[/itex]. To also obtain the same electric field, one has to set
[tex]\Phi'=\Phi-\partial_t \chi.[/tex]
Indeed, then we have
[tex]-\partial_t \vec{A}'-\vec{\nabla} \Phi'=-\partial_t \vec{A} - \vec{\nabla} \Phi - \partial_t \vec{\nabla} \chi + \vec{\nabla} \partial_t \chi=-\partial_t \vec{A} - \vec{\nabla} \Phi=\vec{E}.[/tex]
Thus one can implement an auxilliary constraint to determine the scalar and vector potentials from the inhomogeneous Maxwell equations. This is called "fixing the gauge". It is easy to show that gauge invariance implies necessarily the conservation of electric charges, i.e., that it is necessary for the theory to be consistent that the electric charge density and current fulfill the continuity equation,
[tex]\partial_t \rho+\vec{\nabla} \cdot \vec{j}=0.[/tex]
The U(1) character of the transformation comes into play when considering a quantum theoretical model for matter. As a simple example take non-relativistic spinless particles, described (in the position representation) by a wave function, [itex]\psi[/itex].
First, quantum theory is invariant under global U(1) transformations since the absolute phase of the wave function cannot be relevant for physical observables, i.e., the wave function,
[tex]\psi'(t,\vec{x})=\exp(\mathrm{i} \alpha) \psi(t,\vec{x})[/tex]
describes precisely the same state as [itex]\psi(t,\vec{x})[/itex] as long as [itex]\alpha \in \mathbb{R}[/itex].
The Schrödinger equation of a free particle can be derived from the Hamilton principle of stationary action with the Lagrange density
[tex]\mathcal{L}=\psi^* \mathrm{i} \partial_t \psi+\frac{1}{2m} (\vec{\nabla} \psi^*)\cdot (\vec{\nabla} \psi),[/tex]
and indeed this Lagrangian is invariant under the above introduced U(1) transformation. However, for this the phase, [itex]\alpha[/itex] must be independent of time and position. That's what's called a "global symmetry".
Now we'd like to make the symmetry local by inventing a covariant derivative such that the covariant space-time derivative transforms also just with a phase factor, even if this phase factor is space-time dependent. To that end one defines
[tex]D_t=\partial_t+\mathrm{i} q \Phi, \quad \vec{D}=\vec{\nabla} - \mathrm{i} q \vec{A}[/tex]
Then one has from
[tex]D_t' \psi'=(\partial_t +\mathrm{i} q \Phi') [\exp(\mathrm{i} \alpha) \psi]=\exp(\mathrm{i} \alpha) [\partial_t \psi + \psi \mathrm{i} \partial_t \alpha + \mathrm{i} q \Phi' \psi] \stackrel{!}{=} \exp(\mathrm{i} \alpha) D_t \psi[/tex]
that
[tex] \mathrm{i} q \Phi=\mathrm{i} q \Phi' + \mathrm{i} \partial_t \alpha \; \Rightarrow \Phi'=
[tex]\Phi' = \phi-\frac{1}{q} \alpha.[/tex]
Using the same arguments with the gradient, one finds
[tex]\vec{A}'=\vec{A}+\frac{1}{q} \vec{\nabla} \alpha.[/tex]
Thus, one has to introduce a scalar and a vector potential transforming under the local U(1) transformations as the electromagnetic fields with the gauge-transformation function,
[tex]\chi=\frac{1}{q} \alpha.[/tex]
That means that the minimal way to make the Schrödinger equation invariant under local U(1) transformations is to use the covariant derivative instead of the usual partial derivatives in its Lagrangian, leading to
[tex]\mathcal{L}=\mathrm{i} \psi^*(\partial_t+\mathrm{i} q \Phi) \psi +\frac{1}{2m} [(\vec{\nabla}-\mathrm{i} q \vec{A}) \psi]^* \cdot [(\vec{\nabla}-\mathrm{i} q \vec{A}) \psi].
[/tex]
The field equations for the wave function according to the Hamilton principle of stationary action leads to the Schrödinger equation for a particle in a given electromagnetic field, described by the scalar and vector potential. Thus, one can derive interactions in an elegant way by assuming that a previously global gauge symmetry of a model of free particles should be made a local gauge symmetry.
Starting with more complicated groups than the U(1), e.g., SU(2) or SU(3), one can build more involved interactions, socalled non-abelian gauge theories (since these groups are non-abelian).
What all the formulas in vanhees' post mean is the following:
A charged particle has some "momentum" (in the sense of canonical momentum) around the U(1) circle. That is, the particle's phase rotates as a function of time. Whether a particle is "positively charged" or "negatively charged" depends on whether the particle's phase rotates counterclockwise or clockwise (notice in vanhees' formulas that the charge q multiplies the imaginary unit).
For non-Abelian gauge theories, the idea is similar. We consider each charged particle to have a copy of the Lie algebra attached to it as some "internal space". The particle has canonical momenta inside this internal space which classify the kinds of "charge" it can have.
Related to Fundamental Forces and Lie Groups
1. What are the four fundamental forces in physics?
The four fundamental forces in physics are gravity, electromagnetism, strong nuclear force, and weak nuclear force. These forces govern the interactions between particles and are essential for understanding the behavior of matter at the most fundamental level.
2. What are Lie groups and how are they related to fundamental forces?
Lie groups are mathematical groups that describe the symmetries of physical systems. They are closely related to fundamental forces because they help us understand how these forces behave and interact with each other.
3. How do fundamental forces affect the behavior of matter?
Fundamental forces are responsible for the interactions between particles that make up matter. For example, the electromagnetic force is responsible for holding atoms together, while the strong nuclear force holds the nucleus of an atom together. These forces also determine the properties and behaviors of matter, such as its stability and ability to interact with other matter.
4. What is the role of symmetry in understanding fundamental forces?
Symmetry is an important concept in understanding fundamental forces. The symmetries described by Lie groups help us understand the underlying principles and patterns that govern the behavior of these forces. Additionally, symmetries can often reveal relationships between different fundamental forces and help us unify them into a single theory.
5. Can fundamental forces be unified into a single theory?
One of the biggest goals in modern physics is to unify the four fundamental forces into a single theory. This would allow us to fully understand the behavior of matter and the universe at all scales. While there have been significant advancements in this area, a complete and satisfactory theory of everything has yet to be achieved.
  • Beyond the Standard Models
  • Quantum Physics
