I Fundamental matrix of a second order 2x2 system of ODEs
EinsteinCross
Let ## \mathbf{x''} = A\mathbf{x} ## be a homogenous second order system of linear differential equations where
A = \begin{bmatrix}
a & b\\
c & d
\end{bmatrix}
## and ##
\mathbf{x} = \begin{bmatrix}
x(t)\\ y(t))
\end{bmatrix}
Now to solve this equation we transform it into a 4x4 first order system ##\mathbf{X'} = M\mathbf{X} ## where
M = \begin{bmatrix}
0 & 1 & 0 & 0 \\
a & 0 & b & 0\\
0 & 0 & 0 & 1 \\
c & 0 & d & 0
\end{bmatrix}## and ##
\mathbf{X} = \begin{bmatrix}
x(t)\\ x'(t)
\\ y(t)
\\ y'(t)
\end{bmatrix}
Now solving the first order system by calculating the eigenvalues and corresponding eigenvectors gives us the fundamental matrix for the 4x4 system
\Phi (t) = [[\xi_{1}],[\xi_{2}],[\xi_{3}],[\xi_{4}]]
\begin{bmatrix}
e^{\lambda_{1}t }
\\ e^{\lambda_{2}t }
\\ e^{\lambda_{3}t }
\\ e^{\lambda_{4}t }
\end{bmatrix}^{T} ## where the xi brackets are the eigenvectors in column form.
But my question is this: What I am looking to do is to find the fundamental matrix of the original second order 2x2 system which is represented as ##
\Psi (t) = \begin{bmatrix}
\psi_{1}(t) & \psi_{2}(t)
\\ \psi_{3}(t)
& \psi_{4}(t)
\end{bmatrix} ## such that ##\Psi ''(t) = A\Psi (t)##. So how does one extract the solution(s) to the original 2x2 system from the fundamental matrix of the first order 4x4 system?
It is better to construct your first order system in block matrix form as <br /> \begin{pmatrix} \mathbf{x} \\ \mathbf{x}&#039; \end{pmatrix}&#039; = \begin{pmatrix} 0 &amp; I \\ A &amp; 0 \end{pmatrix}<br /> \begin{pmatrix} \mathbf{x} \\ \mathbf{x}&#039; \end{pmatrix}. Now consider an eigenvector (\mathbf{v}\, \mathbf{u})^T of this with eigenvalue \mu. By definition <br /> \mu \begin{pmatrix} \mathbf{v} \\ \mathbf{u} \end{pmatrix} = \begin{pmatrix} 0 &amp; I \\ A &amp; 0 \end{pmatrix}<br /> \begin{pmatrix} \mathbf{v} \\ \mathbf{u} \end{pmatrix} so that \left. \begin{array}{c}<br /> \mu\mathbf{v} = \mathbf{u} \\ <br /> \mu\mathbf{u} = A\mathbf{v} \end{array}\right\}\quad\Rightarrow\quad A\mathbf{v} = \mu^2 \mathbf{v}. Hence \mu^2 = \lambda is an eigenvalue of A with \mathbf{v} its corresponding eigenvector. This leads to a solution of the form <br /> \mathbf{x}(t) = \mathbf{v}(Ae^{\sqrt{\lambda}t} + Be^{-\sqrt{\lambda}t})
Likes topsquark and EinsteinCross
An equivalent approach is to leave it as a system of second-order ODEs. Start with
$$ \mathbf{x''} = A\mathbf{x} $$
and assume a solution of the form ##\mathbf{x} = \mathbf{x_0} \, e^{\lambda t}##. You then get
$$ \lambda^2 \mathbf{x_0} = A\mathbf{x_0}. $$
which is a standard eigenvalue problem. This is the approach I always use for equations of this form.
jason
Likes malawi_glenn and topsquark
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
