Fundamental of Physics 10th Edition Problem 52
In summary, the conversation discusses the calculation of time, velocity, and equations for a bolt that is dropped from a bridge. The correct answer for part (a) is given, but parts (b) and (c) require additional equations to be learned.
kmshowalter
A bolt is dropped from a bridge under construction, falling 83 m to the valley below the bridge. (a) How much time does it take to pass through the last 20 % of its fall? What is its speed (b) when it begins that last 20 % of its fall and (c) just before it reaches the ground?
For part (a) I got the correct answer of .436 seconds by doing 83/4.9=16.94, sqrt16.94=4.12
83 x .20 = 16.6
83-16.6=66.4
66.4/4.9=13.55
sqrt13.55=3.68
4.12-3.68=.436
That answer was correct but I need parts (b) and (c)
Knowing the time something is falling under gravity, how do you calculate the velocity? You've learned one equation of kinematics; there's a couple more equations you need to learn as well.
I'm sorry but that really doesn't help my understanding of how to do it.
It means there are some other equations that you need to learn:
http://mathematicsi.com/deriving-suvat-equations-motion/
as well.
For part (b), we can use the equation v = gt, where v is the final velocity, g is the acceleration due to gravity (9.8 m/s^2), and t is the time. We know that the final velocity when the bolt begins the last 20% of its fall will be the same as the initial velocity of the last 20% of its fall. So, using the calculated time from part (a) of 0.436 seconds, we can plug it into the equation to get: v = (9.8 m/s^2)(0.436 s) = 4.28 m/s. Therefore, the speed at the beginning of the last 20% of the fall is 4.28 m/s.
For part (c), we can use the equation v^2 = u^2 + 2as, where v is the final velocity, u is the initial velocity, a is the acceleration, and s is the displacement. We know that the displacement for the last 20% of the fall is 16.6 m (as calculated in part (a)). We also know that the initial velocity is 4.28 m/s (as calculated in part (b)). And the acceleration is still 9.8 m/s^2. Plugging these values into the equation, we get: v^2 = (4.28 m/s)^2 + 2(9.8 m/s^2)(16.6 m) = 182.48 m^2/s^2. Taking the square root of both sides, we get: v = 13.5 m/s. Therefore, the speed just before the bolt reaches the ground is 13.5 m/s.
Related to Fundamental of Physics 10th Edition Problem 52
1. What is the overall structure of the "Fundamentals of Physics 10th Edition Problem 52"?
The "Fundamentals of Physics 10th Edition Problem 52" is a question from the 10th edition of the textbook "Fundamentals of Physics" written by David Halliday, Robert Resnick, and Jearl Walker. It is a problem that challenges students to apply their understanding of the fundamental principles of physics to solve a specific scenario.
2. What is the topic or concept covered in "Fundamentals of Physics 10th Edition Problem 52"?
The topic covered in "Fundamentals of Physics 10th Edition Problem 52" is projectile motion. It requires students to apply the equations and principles of projectile motion to determine the maximum height and range of a projectile launched at a given velocity and angle.
3. Is "Fundamentals of Physics 10th Edition Problem 52" suitable for all levels of physics students?
"Fundamentals of Physics 10th Edition Problem 52" is suitable for students at the introductory level of physics, as it covers the fundamental principles and equations of projectile motion. However, it may also be challenging for students with no prior knowledge of physics.
4. What skills or knowledge do students need to have in order to solve "Fundamentals of Physics 10th Edition Problem 52"?
Students need to have a solid understanding of the fundamental principles of physics, including vectors, kinematics, and projectile motion equations. They should also be familiar with basic algebra and trigonometry to solve for unknown variables in the problem.
5. Can "Fundamentals of Physics 10th Edition Problem 52" be solved using only theoretical knowledge or does it require practical experimentation?
"Fundamentals of Physics 10th Edition Problem 52" can be solved using only theoretical knowledge and equations. However, students may benefit from visualizing and understanding the scenario through practical experimentation or simulations.
