Fundamental problem regarding mole concept
In summary: For example, "2 moles of hydrogen and 1 mole of oxygen combine to form 1 mole of water".In summary, Amount of substance is a fundamental physical quantity which has mole (mol) as it's SI unit. Therefore all expressions for amount of substance should have the unit mole on simplification.
donaldparida
146
Background: Amount of substance is a fundamental physical quantity which has mole (mol) as it's SI unit. Therefore all expressions for amount of substance should have the unit mole on simplification.
Therefore, if A = Amount of substance (normally in moles), m = Mass of the substance in a particular unit (normally in grams), M is the mass per unit amount of substance (normally in grams/mole), then,
A = m/M
If the substance is a molecule then M is known as molar mass of the substance.
But in my textbook and in many websites on the internet, I have encountered the phrase number of moles. I think it refers to the amount of substance or may be the numerical part in the amount of substance. The formulas given there were strange.
If n is the number of moles, m is the mass of the substance in grams and x is the atomic weight (for atoms of elements) or molecular weight (for molecules of elements and compounds), then,
n = m/x
This equation is not dimensionally correct if I am right.
My questions:
First of all i would like to ask whether amount of substance and number of moles refer to the same thing or is it that amount of substance has a unit along with a numerical value whereas number of moles does not have a unit and represents the numerical value in the magnitude of the amount of substance.
Secondly, between equations 1 and 2, which one is completely correct (both in meaning and dimension)?
Thirdly, since in some place I have encountered gram atomic/molecular mass in place of molar mass, i would like to know what are the differences between both and do they have the same units or different units?
Chemistry news on Phys.org
The only difference is that in first one you have ##g/\mathrm{mol}## as the unit of denominator whereas it is ##g## in second one. First one is dimensionally correct but it does not matter.
Amount of substance can be in dozens but number of moles will be in moles.
mol is just one unit for the amount of a substance and you could use other units as well (a mol of atoms, a dozen eggs, a ream of paper). Amount of substance can be converted to number of moles through Avogadro's constant: 6.02e23/mol.
For example, for one helium atom * mol/6.02e23 = 1.66e-24 mol. Similarly, one helium atom * dozen/12 = 0.083 dozen.
Atomic/molecular weights are generally given in g/mol so taking a mass and dividing it by the molecular weight will give number of moles.
@Buffu , so number of moles has the unit moles. Right?
MOLES is used as a unit of measure, and can be abbreviated "mol". This unit is the count of 6.022*10^23 of whatever pieces are being counted.
DOZEN is used as a unit of measure, abbreviated in whatever way will be useful or understood. This unit is a count of 12 of whatever pieces are being counted.
Yes, therefore, I think that amount of substance should be the preferred word, which is also the view upheld by IUPAC.
Likes Buffu
Moles are a better unit for making some statements. For example, "2 moles of hydrogen and 1 mole of oxygen combine to form 1 mole of water". That is close to "2 grams of hydrogen and 16 grams oxygen make 18 grams water" but not exactly. The hydrogen and oxygen could have isotopes so the mass can vary depending on how much deuterium, oxygen18 we mix in. Pure single proton hydrogen also has slightly more mass than 1 gram per mole. Then there is a slight loss in mass because energy is released in the chemical reaction. If you state the equation using mols you can disregard the extras and just express the chemical reaction.
Related to Fundamental problem regarding mole concept
1. What is the fundamental problem regarding the mole concept?
The fundamental problem regarding the mole concept is that it is not a tangible unit of measurement. It is a theoretical concept used to represent a specific amount of substance. This can make it difficult for students to understand and grasp the concept.
2. Why is the mole concept important in chemistry?
The mole concept is important in chemistry because it allows us to accurately measure and compare the number of particles in a substance. This is crucial in chemical reactions and calculations, as it helps us determine the amount of reactants needed and the amount of products produced.
3. How is the mole concept related to Avogadro's number?
The mole concept is directly related to Avogadro's number, which is approximately 6.02 x 10^23. This is the number of particles (atoms, molecules, etc.) in one mole of a substance. Avogadro's number allows us to convert between moles and particles in calculations.
4. What is the difference between a mole and a gram?
A mole is a unit of measurement for the amount of substance, while a gram is a unit of measurement for mass. One mole of a substance will always have the same number of particles, regardless of the substance's mass.
5. How can I better understand the mole concept?
To better understand the mole concept, it is helpful to practice converting between moles and particles, as well as performing calculations involving moles. Visual aids, such as diagrams or models, can also aid in understanding the concept. Additionally, seeking clarification and asking questions from a teacher or tutor can also help improve understanding.
17K
  • Other Physics Topics
