Fundamental theorem of algebra
In summary, the conversation discusses the two versions of the fundamental theorem of algebra and how they are related. The first version states that a polynomial of degree n has n roots, while the second version states that a polynomial can be factored into linear and irreducible quadratic factors. It is mentioned that the second version implies the first version, but it is unclear how the first version implies the second version. The concept of complex conjugate pairs is brought up as a way to understand this implication.
ehrenfest
2,020
There are two versions of the fundamental theorem of algebra, one that says a polynomial of degree n has n roots and the other that says a polynomial can be factored into linear and irreducible quadratic factors. Is there a quick way to see how they are the same?
The 2nd version is talking within the real numbers ie A polynomial with real coefficients can be factored into linear and irreducible quadratic factors over R.
The first version is the same because the factor theorem says that for P(x), if g is a root then (x-a) is a factor. We can use the quadratic formula too see that any quadratic factor can be factored into linear factors, if factored over C instead of R.
I see why the second version implies the first version. I do not see why the first version implies the second version.
How do you know that you can get rid of all of the factors (x - a) where a is complex, since the 2nd version really says that A polynomial with real coefficients can be factored into linear and irreducible quadratic with real coefficients.
O yes I forgot about that implication. Remember the complex conjugate theorem, which states the for polynomials with real coefficients, complex roots will come in conjugate pairs.
FAQ: Fundamental theorem of algebra
What is the Fundamental Theorem of Algebra?
The Fundamental Theorem of Algebra states that every non-constant polynomial equation with complex coefficients has at least one complex root.
Who discovered the Fundamental Theorem of Algebra?
The Fundamental Theorem of Algebra was first proved by mathematician Carl Friedrich Gauss in 1797.
Why is the Fundamental Theorem of Algebra important?
The Fundamental Theorem of Algebra is important because it provides a fundamental understanding of the behavior of polynomial equations with complex coefficients. It also has numerous applications in other areas of mathematics and science.
How is the Fundamental Theorem of Algebra used in real life?
The Fundamental Theorem of Algebra has several real-life applications, including in engineering, physics, and computer science. It is used in fields such as signal processing, control systems, and image processing to analyze and solve complex problems.
Is the Fundamental Theorem of Algebra a difficult concept to understand?
The Fundamental Theorem of Algebra can be a difficult concept to fully grasp, especially for those new to the study of mathematics. However, with proper study and practice, it can be understood and applied effectively.
