Fundamental theorem of calculus (something isn't right)
In summary, the theorem stated that if a function is continuous on an interval, then its derivative is also continuous on that interval. However, there is a problem with this theorem if the derivative of the function is not continuous or defined at the point.
  • #36
Thanks for the explanation jgens. I partially understand what are you saying to me, but I can't really see the big difference. Suppose [-1,x] is interval on which I need to find the area on. So A(x) would be the area. But it can be seen that [itex]\int_{f(x)dx}[/itex]=A(x) or A'(x)=f(x). I also checked wikipedia.
Here is what I found:
wikipedia said:
In calculus, an antiderivative, primitive or indefinite integral[1] of a function f is a function F whose derivative is equal to f, i.e., F ′ = f. The process of solving for antiderivatives is antidifferentiation (or indefinite integration)
  • #37
If you want a simple illustration of how they're different, consider the function [itex]f[/itex] defind by [itex]f(x) = 0[/itex] if [itex]x = 1[/itex] and [itex]f(x) = 1[/itex] otherwise. Now suppose that I want to evaluate [itex]\int_0^xf[/itex]. It's a trivial exercise to show that [itex]\int_0^xf = x[/itex]. Now if integration were the inverse process of differentiation we would have that [itex](x)' = 1 = f(x)[/itex] which clearly isn't true. Does this make sense?
  • #38
If x=1:
[tex]
\int_0^xf(t)dt= \int_0^x0dt=0(\int_0^x1dt)+C=C
[/tex]
If [itex]x\neq 1[/itex]
[tex] \int_0^x1dt=(t+C_1)|_0^x = x-0=x[/tex]
It still valid:
[tex]F(x)=\left\{\begin{matrix}
C, x=1\\
x, x \neq 1
\end{matrix}\right.[/tex]
[tex]f(x)=F'(x)=\left\{\begin{matrix}
0, x=1\\
1, x \neq 1
Edit: This function does not satisfy the theorem, its not continuous, so it fails to work anyway.
  • #39
njama said:
If x=1:
[tex]
[/tex]
It still valid:
C, x=1\\
x, x \neq 1
0, x=1\\
1, x \neq 1
You cannot just swap f(x) for zero, because the integral "doesn't ask" the function what's its value on a certain point, but what's its value on an interval. Therefore the integral goes through "many" points in which f(x)=1, bumps into a zero, and then goes on. (This is a point where I recommend to read again about integrals, and exercise them, because what you did in the first lines "if x=1 blahblah" show you don't completley understand how to work with them and what do they mean)
But we know that changing a function in a finite number of points, doesn't change its integral, so as far as the integral "knows" he's actually integrating only f(x)=1.
Anti-differentiation, if studied as an operator, must consider any information in f(x), while integration loses this little things that make up f(x).
  • #40
njama said:
If x=1:
[tex]
[/tex]
It still valid:
C, x=1\\
x, x \neq 1
0, x=1\\
1, x \neq 1
No, no, no! This isn't right in the slightest. You can't just integrate using the FTC if [itex]f[/itex] isn't continuous. You need to go back using the definition of the integral like the one that I provided and not what you mistakenly keep taking as the definition of the integral.
Anyway, once you actually do the exercise correctly, you will find that [itex]\int_0^xf = x[/itex]; hence, even though [itex]f[/itex] isn't continuous, this integral is. Now, if integration and anti-differentiation were the same thing, differentiating [itex]\int_0^xf[/itex] would show that [itex]f(x) = 1[/itex] which is clearly false. Therefore, anti-differentiation and integration are not the exact same thing.
  • #41
OK. You defined the function like this:
And you told me to find:
[itex]
\int_0^bf
[/itex]
Now. If the function is continuous on interval [0,b] then it is integrable on [0,b].
But if function is bounded and have finitely many discontinuity on [0,b] it is still integrable.
So, we can find
[itex]
\int_0^bf
[/itex]
Lets consider any partition on [0,b]. Then either [itex]x_{k}^{*}=0[/itex] or it does not.
If not then
[tex]\sum_{k=1}^{n}f(x_{k}^{*})\Delta x_{k} = \sum_{k=1}^{n}\Delta x_{k} = b[/tex]
else
[tex]\sum_{k=1}^{n}f(x_{k}^{*})\Delta x_{k} = -\Delta x_{k} + \sum_{k=1}^{n}\Delta x_{k} = b - \Delta x_{k}[/tex]
which means that the difference between the Riemann sum and b is at most [itex]\Delta x_{k}[/itex]. BUT, since [itex]\Delta x_{k}[/itex] approaches zero as [itex]max \Delta x_{k} \rightarrow 0[/itex] it follows that:
[tex]\int_{0}^{b}f(x)dx = b[/tex]
But the Fundamental Theorem of Calculus Part 2 states that "If f is continious on an interval [0,b] then f has an antiderivative on [0,b]. In particular if a is any number in [0,b] then the function F defined by:
[tex]F(x)=\int_{a}^{x}f(t)dt[/tex]
is an antiderivative of f on [0,b]; that is F'(x)=f(x) for each x in [0,b], or in an alternative notation:
[tex]\frac{d}{dx}\left [ \int_{a}^{x}f(t)dt \right ] = f(x)[/tex]
So f must be continious so that we can conclude that f has an antiderivative. If f is not continious anything can follow.
  • #42
Except for the fact that [itex]f[/itex] clearly isn't continuous so the FTC isn't applicable here. The point of this exercise was to illustrate that if [itex]F[/itex] is a function defined by [itex]F = \int_0^xf[/itex], then [itex]F'[/itex] is not necessarily equal to [itex]f[/itex] as you asserted in post number 30 of this thread.
