Fundamental trignometry problem
In summary, the standard definition of sine theta is the ratio of the length of the leg opposite angle theta to the length of the hypotenuse in a right triangle. This definition is commonly used to solve practical problems involving right triangles.
mritunjay
how is trignometric ratios like sine theta is defined to be the ratio of perpendicular and hypotenuse in a right angled triangle?
Perhaps you need to find a better translation of your question, this does not make much sense.
A definition is whatever you want it to be. The standard definition of sin([itex]\theta[/itex]), where [itex]\theta[/itex] is an angle in a right triangle, is "length of the leg opposite angle [itex]\theta[/itex] divided by the length of the hypotenuse", which is, I guess, what you meant by "vertical". If you meant why it was defined that way, then the only reasonable answer is "because that definition helps to solve many practical problems involving right triangles".
FAQ: Fundamental trignometry problem
1. What is fundamental trigonometry?
Fundamental trigonometry refers to the basic principles and concepts of trigonometry, which is the branch of mathematics that deals with the relationships between the sides and angles of triangles.
2. What are the three fundamental trigonometric functions?
The three fundamental trigonometric functions are sine, cosine, and tangent. These functions are used to calculate the ratios between the sides of a right triangle.
3. What is the unit circle and how is it related to fundamental trigonometry?
The unit circle is a circle with a radius of 1 unit, centered at the origin of a Cartesian coordinate system. It is used in trigonometry to relate the values of the trigonometric functions to the angles in a right triangle.
4. How is fundamental trigonometry used in real life?
Trigonometry is used in a variety of fields such as engineering, physics, navigation, and astronomy. It is used to solve problems involving angles, distances, and heights, and is essential in the construction of buildings, bridges, and other structures.
5. What are some common applications of fundamental trigonometry?
Some common applications of fundamental trigonometry include solving right triangles, calculating the heights and distances of objects, and analyzing periodic phenomena such as sound and light waves. Trigonometry is also used to solve problems in navigation, surveying, and satellite technology.
