Fusion Reaction of Hydrogen and Deuterium into Helium
In summary, fusion reactions involve the joining of two atoms to form a new element, with a fraction of the rest energy converted to kinetic energy. In the specific reaction of hydrogen and deuterium forming helium and a gamma ray, the system's total kinetic energy before the particles touch can be calculated using the given equations. However, when considering the kinetic energy of the reaction products, it is important to account for the momentum of the photon, leading to a different answer.
ankitgu
In a fusion reaction, the nuclei of two atoms join to form a single atom of a different element. In such a reaction, a fraction of the rest energy of the original atoms is converted to kinetic energy of the reaction products. A fusion reaction that occurs in the Sun converts hydrogen to helium. Since electrons are not involved in the reaction, we focus on the nuclei.
Hydrogen and deuterium (heavy hydrogen) can react to form helium plus a high-energy photon called a gamma ray:
[tex] ^1H + ^2H \rightarrow ^3He + \gamma[/tex]
Objects involved in the reaction:
Code:
Particle        # of protons    # of neutrons    Charge    Rest Mass (atomic mass units)
[sup]1[/sup]H (proton)     1               0                +e        1.0073
[sup]2[/sup]H (deuterium)  1               1                +e        2.0136
[sup]3[/sup]He (helium)    2               1                +2e       3.0155
gamma ray       0               0                0         0
Code:
Constant                  Value to 5 significant figures
c (speed of light)        2.9979e8 m/s
e (charge of a proton)    1.6022e-19 coulomb
atomic mass unit          1.6605e-27 kg
[tex]\frac{1}{4 \pi \epsilon_0}[/tex]                      8.9875e9 N·m[sup]2[/sup] /C[sup]2[/sup]
A proton (1H nucleus) and a deuteron (2H nucleus) start out far apart. An experimental apparatus shoots them toward each other (with equal and opposite momenta). If they get close enough to make actual contact with each other, they can react to form a helium-3 nucleus and a gamma ray (a high energy photon, which has kinetic energy but zero rest energy). Consider the system containing all particles. Work out the answers to the following questions on paper, using symbols (algebra), before plugging numbers into your calculator.
The deuterium nucleus starts out with a kinetic energy of 1.54e-13 joules, and the proton starts out with a kinetic energy of 3.08e-13 joules. The radius of a proton is 0.9e-15 m; assume that if the particles touch, the distance between their centers will be twice that.
1. What will be the total kinetic energy of both particles an instant before they touch? (I got this)
2. What is the kinetic energy of the reaction products (helium nucleus plus photon)? (I need help)
[tex]E_f = E_i + W[/tex]
[tex]W = -\Delta U = U_i - U_f[/tex]
[tex]E = m c^2 + K[/tex]
[tex]U_{elec} = \frac{1}{4 \pi \epsilon_0} \frac{q_1 q_2}{r}[/tex]
Number 1:
Answer: 3.34e-13
DeltaE = DeltaKE + Delta PE
0 = KEf-KEi+PEf-PEi
KEf = what we want
KEi = given
PEf = 9e9*(-1.6e-19)^2/1.8e-15
PEi = 0
Number 2:
DeltaE = KEf - KEi + PEf - PEi
0 = KEf - KEi + PE(coloumbs final) - PE(coloumbs initial) + PE(R final) - PE(R initial)
KEf = what we want
KEi = answer to #1
PE(coloumbs final) = 0, b/c photon has no mass
PE(coloumbs initial) = 9E9*(-1.6e-19)^2/1.8E-15
PE(R final) = Mass(helium)*c^2
PE(R initial) = Mass(deuterium + proton)*c^2
My answer for KEf = 2.71395E17
Where did I go wrong on #2?
Photons have momentum. In order for the system to conserve momentum,...
Related to Fusion Reaction of Hydrogen and Deuterium into Helium
1. What is fusion reaction and how does it work?
Fusion reaction is a process in which two or more atomic nuclei combine to form a heavier nucleus. In the case of hydrogen and deuterium fusion, the nuclei of these atoms combine to form a helium nucleus. This process releases a large amount of energy in the form of heat and light. Fusion reactions occur naturally in stars, including our sun, and are also being studied for potential use as a clean and efficient energy source.
2. What are the reactants and products in a fusion reaction of hydrogen and deuterium into helium?
The reactants in this fusion reaction are hydrogen (H) and deuterium (D) atoms. The products are a helium (He) nucleus, along with a release of energy in the form of heat and light.
3. What are the conditions required for a successful fusion reaction of hydrogen and deuterium into helium?
Fusion reactions require extremely high temperatures and pressures to overcome the repulsive force between positively charged nuclei. For the fusion of hydrogen and deuterium into helium, temperatures of at least 100 million degrees Celsius and pressures millions of times greater than Earth's atmospheric pressure are needed.
4. What are the potential benefits of hydrogen and deuterium fusion as an energy source?
One of the potential benefits of hydrogen and deuterium fusion is that it produces a large amount of energy while producing very little radioactive waste. It also relies on abundant resources, as hydrogen and deuterium can be extracted from seawater. Fusion reactions also do not emit greenhouse gases, making it a potentially cleaner source of energy compared to fossil fuels.
5. What are the challenges and obstacles in achieving successful fusion reactions of hydrogen and deuterium into helium?
One of the main challenges in achieving successful fusion reactions is the difficulty in controlling and sustaining the high temperatures and pressures required. Another challenge is finding suitable materials to contain and withstand the extreme conditions of fusion reactions. Additionally, the energy input required to initiate and sustain fusion reactions is currently greater than the energy output, making it an ongoing area of research and development.
11K
  • Science Fiction and Fantasy Media
