I G-force centrifuge mounted on opposite rotating platform
A query was raised about whether a centrifuge creating a specific g-force, mounted on a counter-rotating platform, negates the g-force experienced by an occupant. The discussion highlights the need for clarity on the arrangement and motion of the centrifuge and platform, suggesting that a visual representation could aid understanding. Participants are uncertain about the dynamics involved, particularly how the rotation affects the perceived motion of the occupant from an external viewpoint. The conversation emphasizes the complexity of the scenario and the importance of accurately defining the system's parameters. Overall, the interaction seeks to clarify the physics behind the setup and its implications on g-force perception.
DonnyJ
TL;DR Summary
Query - does a centrifuge spinning to create X g-force, mounted on a platform that is rotating the the same rpm's the opposite direction, negate the g-force? Or does the g-force stay the same but from an outside perspective the centrifuge appears stationary?
Welcome to PF.
What do you think the answer is and why? Do you know how to write the equation of motion of an object in the centrifuge as seen in a rest frame in the laboratory?
Also, can you show us a sketch or picture of the arrangement you are asking about? You can use the "Attach files" link below the Edit window to add PDF or JPEG images to your posts.
As @berkeman says, a drawing will help.
It sounds like you have two concentric cages, with the outer one rotating and the inner one not, Is that correct? If so, does that give you any ideas?
I have only one clarifying question for the OP:
From the vantage point of an observer outside the centrifuge contraption, how fast (if at all) is the occupant rotating?
I have no real clue what the OP is asking about lol, not the best statement that describes accurately the situation. The best I can make of it is that we have some object that is rotating around some point in a lab, say clockwise, and the whole lab is rotating (around the same point or different point?) in an opposite direction counterclockwise.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
